dana 50 axle - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2008, 12:09 PM   #21
95geo
newbie
95geo's Avatar
Originally Posted by special ed View Post
I see your wimpy "fitty", and raise you a Spicer/Dana 70 front axle. How many points do I get for that, and the stock front lift blocks.
you are automatically dq'd for closed knuckle.... that thing might as well be a toyota axle
a dana 50 is metric, from memory it has a 44 sized pinion and a larger ring gear but not dana 60 sized.
if I were going to spend money on an axle that would be one of my last choices, it all depends on what you want out of it and what you plan to change to make it that way.
Old June 7th, 2008, 12:23 PM   #22
kickstand
circling the drain
kickstand's Avatar
If it works for you great. Thats all that matters.
Old June 7th, 2008, 12:26 PM   #23
KartRacer
Blowd up
KartRacer's Avatar
Toyota axle ownzzzz
Old June 7th, 2008, 01:02 PM   #24
Originally Posted by KartRacer View Post
Toyota axle ownzzzz
Yeah, owns a crappy turning radius, weak joints, and a small ring gear...
Old June 7th, 2008, 01:06 PM   #25
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Originally Posted by masterbeatty View Post
the axle can be converted to a dana 60. at least that is what i am told.
To do this simple conversion, all you do is remove the Dana 50 and install the Dana 60.
Originally Posted by UP_ROKTOY View Post
the kid that told you that was drunk.
Extremely.
Originally Posted by Mike Hancho View Post
what about the 44hd...the 44 ring and the 60 pinion...had one in my viper and I did break the pinion and not the ring....
It's still a Dana 44 pinion, just the shaft is the same diameter as the Dana 60, but it still has 26 splines, not 29 like the Dana 60.
Old June 7th, 2008, 01:41 PM   #26
MotoX5874
unbound
MotoX5874's Avatar
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
MotoX5874 is offline   Reply With Quote
Old June 7th, 2008, 01:47 PM   #27
zjguy721
Insomniac
zjguy721's Avatar
OK, on a serious note, just what exactly is the difference between a 50 and a 60? There seem to be some varying opinions on here. I have been told that it is a 60 housing with 44 internals, but who really knows.
zjguy721 is offline   Reply With Quote
Old June 7th, 2008, 04:59 PM   #28
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
that wasn't what broke...the pinion itself cracked in several places
Old June 7th, 2008, 05:13 PM   #29
Jeeperz Creeperz
GL 4x4 Vendors
The Dana 50 has a 9" ring gear, the Dana 60 has a 9.75" ring gear.
The Dana 50 has 30 spline shafts (shafts neck down to Dana 44 size), the Dana 60 has 1.5" 35-spline shafts.
The Dana 50 uses a modified Dana 44 carrier (Dana 50 carrier was discontinued).
The housing is a Dana 60 size housing (use same diff covers) but I don't believe you can put a Dana 60 diff/gear in it (never tried).
So, in essence, it is a Dana 60 housing but although the parts are Dana 44 size-ish, they are not Dana 44 parts.
Old June 7th, 2008, 05:17 PM   #30
Jeeperz Creeperz
GL 4x4 Vendors
That's what I said. A 26-spline pinion.
Old June 8th, 2008, 02:06 AM   #31
Mclovin
"The Situation"
Mclovin's Avatar
when u rev it to 8grand and dump the clutch with sticky racing slicks SOMETHING has to give
Wait.. how'd you break it
Old June 8th, 2008, 02:08 AM   #32
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
i hate dana 50's and you kthanksbye
Old June 8th, 2008, 02:08 AM   #33
Mclovin
"The Situation"
Mclovin's Avatar
PS These will solve all your issues on this site guy...
buy those put em in your rig and NO ONE will EVER tell you your axles arent strong enough !!!
Old June 8th, 2008, 09:43 AM   #34
Christmas Cookie
call me stupid but isn't a 26-spline pinion the number of splines on the end of the yoke? if that holds true then your statement doesn't...26 or 29 splines would have made no difference ...the pinion gear itself cracked, not the shaft, not the splines
Old June 9th, 2008, 08:56 AM   #35
Jeeperz Creeperz
GL 4x4 Vendors
It's irrelevant where it broke, I was simply comparing sizes. Diameter usually increases with spline count (ie, the higher the spline count the larger the diameter).
My point was more along the lines that the pinion is still a Dana 44 pinion, not a Dana 60 pinion, although in this case they are the same diameter.
Old June 9th, 2008, 10:03 PM   #36
masterbeatty
masterbeatty's Avatar
wow screw you to
Old June 9th, 2008, 10:20 PM   #37
kickstand
circling the drain
kickstand's Avatar
wow screw you to
Old June 9th, 2008, 10:45 PM   #38
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
psssshhhh... forget those overpriced boat anchor 9" crap shop here in the 5 ton section.
http://www.boyceequipment.com/pricel...;20Ton%20Axles
Old June 9th, 2008, 10:50 PM   #39
unclebeaner
wow screw you to
wanna hug hippie?
Old June 10th, 2008, 10:08 AM   #40
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Originally Posted by benny87 View Post
Im still running my 35s on my dana 30/35 and havent broken anything at ALL for 3 years and I do wheel it hard.
no you don't
Page generated in 0.50860 seconds with 82 queries
