Another 1ton YJ "56k beware" - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2008, 12:01 PM   #21
IHCJ9
IHCJ9's Avatar
No problem. One thing we have done in the past is run HDPE runners down the link on the bottom side, helps them slide over rocks, etc.
Again, just a suggestion.
IHCJ9 is offline   Reply With Quote
Old December 15th, 2008, 12:09 PM   #22
cruzer72
cruzer72's Avatar
Very Nice work. You working on that at G2 Inc. ? Cause the green jeep looks familiar.
cruzer72 is offline   Reply With Quote
Old December 15th, 2008, 12:11 PM   #23
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
most people run 7075 aluminum
i never bent one far enough it didnt spring back.
Old December 15th, 2008, 12:16 PM   #24
beejers
always building
beejers's Avatar
Yeah G2. I live across the street. Its nice and warm over there.
beejers is offline   Reply With Quote
Old December 15th, 2008, 12:25 PM   #25
cruzer72
cruzer72's Avatar
Wasn't to hard to figure out . Cedar springs , Pre-cast walls , and a green jeep. Gordy is an awesome guy. He does my axle work.
Old December 15th, 2008, 06:09 PM   #26
cvwindows
I think I can make it!!!!
cvwindows's Avatar
I run 7075 on my jeep and have not had a problem however I ran DOM on my buggy and bent them.
It is amazing how much lighter the aluminum is. I run a smaller diameter on the uppers to help keep the cost down.
Dont change your mind on the aluminum. You will be happy with them
cvwindows is offline   Reply With Quote
Old December 16th, 2008, 09:40 PM   #27
chevotass
chevotass's Avatar
Looks awesome. should be a sweet rig when done. and i love my alluminium links.
Old December 16th, 2008, 09:58 PM   #28
beejers
always building
beejers's Avatar
thanks everyone,,,,,,.About the links,i will end up running the aluminum links. i bought the material and if it dont work i will change it.
I think the aluminum will be the right choice. I watched a tierod made out of 1.5" diameter aluminum get smashed into a rock all the way to the diff cover,,,,,,when the guy finally backed up it went back to straight.
Back to the jeep, been trying to find a intake and oil pan for my motor so i can keep going forward. I think i am going to try to cut and weld my aluminum oil pan myself. I wonder if i can buy a oil pickup for the camaro LS1?
Old December 16th, 2008, 11:54 PM   #29
bbaXJ
Yooper In Training
bbaXJ's Avatar
The pickup shouldn't be too hard to find. I got my LS1 oilpan, windage tray, and pickup used for about $200, that seems to be what they usually go for. Are you looking for an LS1 intake too? They usually sell for about $50, but then you'll need to adapt your accessories too. You could buy a idler pulley relocation bracket and cut down the alternator bracket but that leaves the alternator up as high as the truck intake. I picked up a full set of LS1 accessories/brackets, but the complete setup is fairly hard to find and usually pricey.
By the way, the Juggy looks very nice, good work.
Page generated in 0.46465 seconds with 50 queries
