TJ rear crossmember - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2008, 06:28 AM   #1
jthomp
jthomp's Avatar
Default TJ rear crossmember
Where can I find a rear crossmember cover like Poison Spider uses for their rear stinger. I'm not having any issues, I just like the looks of them and I think it would be a good rear extraction point. I know I could cut one out myself, but it would probably look like .
jthomp is offline   Reply With Quote
Old June 7th, 2008, 09:00 AM   #2
Tab
Tab's Avatar
Have Deaner send you a pick of the one I just made him for his psc rear stinger. I have the file saved too so cutting another one out would be no big deal. Altough if your not using it as the support for a rear stinger then I would go another direction for an extraction point. Its just plate mount to the frame with 8 bolts and my worry would be when pulling on the clevise it would just make the plate flex/bend. Also the psc one comes with backing plates that would help out a lot too.
Old June 19th, 2008, 02:33 PM   #3
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Genright makes 1
http://www.genright.com/ProductInfo....ductid=RBB1001
I'm the man in White.
Page generated in 0.17325 seconds with 32 queries
