Ford Techs here? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 6th, 2008, 02:24 AM   #1
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
Default Ford Techs here?
my 99 mustang gt 5 speed has a problem with the reverse lights, they dont work. i have checked the bulbs and the fuse, all is well, but still no lights. Anyone know what the problem is, or could look up the tsb?
Originally Posted by FlatFender View Post
America! Fuck yeah!
gofastbobby is offline   Reply With Quote
Old June 6th, 2008, 07:52 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
Check the switch that screws into the trans
Old June 6th, 2008, 07:55 AM   #3
Flexin' XJ
Flexin' XJ's Avatar
x2
Flexin' XJ is offline   Reply With Quote
Old June 26th, 2008, 11:46 AM   #4
bronco91shee
bronco91shee's Avatar
Well, Check Fuse 11 At The Smart Junction Box-should Be In Right Kick Panel Under Dash If I Member Right. See If The Orange Wire Coming Out Of That Box Has Power. Then Verify The Reverse Lamp Switch To See If There Is Power In On The Orange, And Out On The Black And Pink When In Reverse. Then It Goes To The Lights, But Also Splices Of To The Gem. This Splice Could Also Be The Issue. Pm Me If You Need To Locate This Splice, I Can Get Ya More Info.
As To Tsb's All I Can Find Is One On A Water Leak Round The Cowl. This Hits The Mustangs Hard, B/c It Usually Leaks Right On To The Sjb, Causing Internal And External Corrision. Obviously Leading To Many Odd Issues. I Would Check For Signs Of Leak, Or Run A Hose On The Car While Being By The Sjb To Verify There Is No Leak.
Hope This Helps
bronco91shee is offline   Reply With Quote
Page generated in 0.19326 seconds with 35 queries
