Trans fluid or gear oil? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 5th, 2008, 12:12 PM   #1
Lemur
i don't much care for you
Lemur's Avatar
Default Trans fluid or gear oil?
in a NP 208 t case? got everything back in for the trans and t case swap and it is leaking like a siv.should have used the gasket AND permatex. trans runs great, but i can see the fluid coming out of the t case right where it meets the mount.
Lemur is offline   Reply With Quote
Old June 5th, 2008, 01:01 PM   #2
Tom
Because racecar
Tom's Avatar
Atf
Old June 5th, 2008, 01:27 PM   #3
Strangler
Strangler's Avatar
My 208 has a tag on it specifing 30wt motor oil. Its the first time I have ever seen that. Mines out of a J-truck.
Old June 5th, 2008, 01:40 PM   #4
Tom
Because racecar
Tom's Avatar
chevy 80s 208 t cases use atf. but i have seen some take 30w oil as well in other models
Old June 5th, 2008, 04:38 PM   #5
ajmorell
ajmorell's Avatar
Usually you can use either. ATF lasts longer than oil though.
Old June 5th, 2008, 04:39 PM   #6
Lemur
Lemur's Avatar
ATF is what is in it now. just wanted to make sure. so i guess i need to pull the t case back off and permatex as well as the gasket. what a bitch
Old June 5th, 2008, 04:51 PM   #7
88mudder
In the band!
my Ford 208 says ATF right on it by the fill plug
Old June 7th, 2008, 07:41 AM   #8
2kids=nojeepmoney
as stated you can run either.
atf in manual trannies and t-cases became popular in the early-mid 80s to reduce driveline drag and increase mileage and lower emissions.
2kids=nojeepmoney is offline   Reply With Quote
Page generated in 0.20749 seconds with 47 queries
