Jeep 1 - Me 0 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2006, 12:44 PM   #1
9T9BlueTJ
Motivator, please!
9T9BlueTJ's Avatar
Default Jeep 1 - Me 0
Sorry if this is the wrong place, but I gotta vent. Took today off to replace my cracked exhaust manifold (see sig). Got everything together and started. Stopped after breaking 2 wiring connectors, fuel rail cover and after a complete brain meltdown, all within 3 hours. Had a Haynes manual and the online Chrysler Tech Manual.
How do you remove the incoming fuel line metal fitting w/ the little internal fingers? How do you remove the fuel injector wire connectors? How do you get to the bottom bolt of the PS pump mount?
Only plus thing was of the bolts that I could reach, none of them broke off!
I think I will live with the crack...
9T9BlueTJ is offline   Reply With Quote
Old April 14th, 2006, 12:54 PM   #2
RICK
Retired double dipper
RICK's Avatar
As I recall last time I "helped" with one of these we did not disconnect the fuel lines, just lifted and folded the fuel rail up out of the way.
The injector plugs are sliding clip/locks.
They are tricky to figure out the first time.
RICK is offline   Reply With Quote
Old April 14th, 2006, 02:16 PM   #3
chris1044
chris1044's Avatar
I cant say I've ever done one, but the fuel lines are going to need a special tool to disconnect....
Old April 14th, 2006, 05:29 PM   #4
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
there's a special tool to remove the fuel line. The bottom bolt wasn't a problem on mine.
Old April 14th, 2006, 05:36 PM   #5
Sonicjay
The special tool is cheap and comes in a multi-pack (for different size lines). I got the set at Sears. It's like a white and black plastic ring that you slide over the line then push towards the hose to remove it.
Sonicjay is offline   Reply With Quote
Old April 14th, 2006, 07:00 PM   #6
rallyemore
Snowman
rallyemore's Avatar
Send a message via AIM to rallyemore
Fuel line disconnectors look like this:
rallyemore is offline   Reply With Quote
Old April 14th, 2006, 08:43 PM   #7
Bandit
Original Furby
Bandit's Avatar
When I did mine I didn't disconnect the fuel line. Just moved it up and out of the way.
From what I remember those bolts are a stretch to get to. Extensions and u-joint adapters helped a ton.
When putting it all back together just watch out the you don't have any wires pinched in-between the manifold. Did that on my brother's jeep and had to take it all apart again. It was a bitch the second time same as it was the first time.
Bandit is offline   Reply With Quote
Old April 14th, 2006, 11:27 PM   #8
SS
Bananarama!
SS's Avatar
Just lift it up and fold it out of the way... that's what I did.. Just make sure to depressurize it.
-Jer
Page generated in 0.21310 seconds with 46 queries
