Project Cumdumpster - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 27th, 2010, 08:35 PM   #141
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by mj23polaris View Post
ok yea its only the driver side tube tearin out of the diff, yea i think makin a truss that goes outside the springs would mean the truss is on the bottom of the axle?
I don't jump my truck 7' in the air but I do enjoy blasting around the dunes and really didn't wanna experience the same fate as my buddy so here's what I did to my 07 Cummins back in August:
12" Fox Remote Resi's are off the Cumdumpster
Lower shock mounts
Upper shock mounts
Bumpstops
Between the longer control arms, progressive bumpstops, and good shocks it was like a whole new truck in the dunes....worked AWESOME. The 800lb-ft was pretty damn nice too!! I just have to keep reminding myself that it's still my DD/towrig and that I need to take it a little easy!
Old September 29th, 2010, 12:01 AM   #142
bbaXJ
Yooper In Training
bbaXJ's Avatar
Back to the black truck....
Added a little more beef
Damn turbo!
Old September 29th, 2010, 02:49 AM   #143
vince43m
vince43m's Avatar
u do very nice fab work
vince43m is offline   Reply With Quote
Old September 29th, 2010, 08:05 AM   #144
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Originally Posted by bbaXJ View Post
They're standard HP60 tubes....something like 3.5"OD, .5" wall if I remember right. The truss is 2" wide so it covers some of the radius at the top and bottom, maybe that makes them look smaller.
3 1/8" 1/2" wall.
I would have started with a 05+ hp60 as they used 3 3/4" 1/2" wall for a truck that heavy. And I bet you could of used the ford's radius arm mounts for the links just about.
Old September 29th, 2010, 09:13 AM   #145
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by Jeepaholic View Post
3 1/8" 1/2" wall.
I wouldn’t have, even if I didn’t already have this axle. We wanted kingpins and rebuildable hubs and the DRW 78-79 HP60 is the perfect width for this truck. Not sure what the WMS-WMS is on the new HP60s though. Besides the fact that the radius arm mounts in the newer Superduties use different bushings and would’ve required chopping up the existing control arms, building a truss around them would’ve been a nightmare, and the existing frame mounts may not have lined up(and those are not moving from where they’re at). The larger tube would’ve been nice but that’s the only benefit of the new HP60 over the one we used, and strength won’t be an issue on this one by any means.
Old October 5th, 2010, 10:07 PM   #146
86scottsdalek10
86scottsdalek10's Avatar
Looking good man. So when is tim's getting finished?
86scottsdalek10 is offline   Reply With Quote
Old October 5th, 2010, 11:51 PM   #147
bbaXJ
Yooper In Training
bbaXJ's Avatar
Should be in the next few weeks. Axles just came out for gear installs, shock hoops and cross brace are 95% done, panhard bar will be in place in another couple nights, steering will be a piece of cake, bumpstops will go quick, etc. It's moving along pretty well and turning out great....I'll post more pics soon.
Old October 6th, 2010, 12:08 PM   #148
buildingup
Looks like a good build so far. What kind of bracing is going on the upper coilover mount? Also what is the wall on the tubing your using?
buildingup is offline   Reply With Quote
Old October 6th, 2010, 12:19 PM   #149
bbaXJ
Yooper In Training
bbaXJ's Avatar
The hoops and crossbrace are all .120" wall DOM, the crossbrace is dual tubes, the hoop mounts are gusseted top and bottom to the frame, etc. Plus there will be proper limit straps and bumpstops so the coilovers won't have to do more than basically support the weight of the rig.
Old October 6th, 2010, 02:04 PM   #150
buildingup
What spring rates you running on the coilovers and are you guys shooting for a certain amount of travel. Then when you going back out to test this cause I want to be present.
Old October 6th, 2010, 04:33 PM   #151
bbaXJ
Yooper In Training
bbaXJ's Avatar
I think based on the calculator we ended up at 500/600 for spring rates. The shocks are currently set at 6.5" of uptravel, 4" of which will be buttery smooth bump travel thanks to the airbumps that arrived at my house last night. Limit straps will stop droop at about 6", so about 12" travel. The rear uses pretty much all of the 14" travel shocks that are back there but still undecided what'll happen cuz Deaver isn't exactly cooperating. There was talk last night of 4 linking the rear with coilovers come springtime....
I don't think we'll be making it up to the dunes again this year to put it to the real test. I'm sure it'll get beat down lightly around here but there's really not much to work with, even with Michigan roads.
Old October 6th, 2010, 05:51 PM   #152
86scottsdalek10
Sweet. Both builds are looking great and your truck looked amazing in person. Now just for that scrambler waiting to be used and abused
Old October 6th, 2010, 05:56 PM   #153
bbaXJ
Yooper In Training
bbaXJ's Avatar
Thanks Brent. Sorry to tell ya, but it's lookin like the Scrambler's gonna get parted out....I need money for a house.
Old October 22nd, 2010, 03:23 PM   #154
Sandster
I see your using the fox shox's with the resi's. i go to silverlake quite a few times in the summer and i like to go fast across the dunes and do some off roadin with my truck was wonderin if the fox shox's are worth the money compared to some of the other brands??? a little off topic but it looks like you have some useage with these shocks
Sandster is offline   Reply With Quote
Old October 24th, 2010, 11:40 PM   #155
bbaXJ
Yooper In Training
bbaXJ's Avatar
As of Thursday night the truck is together and back on the road. Still a few minor things to wrap up but the major stuff is all set and turned out great. I'll post pics soon.
They work great, especially considering how heavy the front end is on these things. My Rancho RSXs that came on the truck sucked hardcore for the dunes and were destroyed FAST. I made some other improvements at the same time as the shocks but the difference is night and day.
Old October 26th, 2010, 03:31 PM   #156
Sandster
My plan is to do a SAS swap on my 99 silverado and kind of end up with something along the lines of what you have a decent off road but still able to drive it everyday.. looks like a lot of time and work.
Old October 26th, 2010, 05:09 PM   #157
bbaXJ
Yooper In Training
bbaXJ's Avatar
Yep it's definitely a lot of work
Old October 26th, 2010, 11:31 PM   #158
Mr. Beefy
BFT!
Mr. Beefy's Avatar
More pic's!!! haha
Old October 27th, 2010, 06:49 AM   #159
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Ive been waiting for pics. I cant sleep till is see pics
Old October 27th, 2010, 07:37 AM   #160
rpratt
rpratt's Avatar
No cage? Looks like a good idea to jump a truck.
It's not as bad as it looks, the doors still open and close.
rpratt is offline   Reply With Quote
Tags
stacks r gay
Page generated in 0.43496 seconds with 84 queries
