Project Cumdumpster - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 4th, 2008, 10:25 PM   #1
bbaXJ
Yooper In Training
bbaXJ's Avatar
Default Project Cumdumpster
My buddy and I just got done building up his '05 CTD. I put my Scrambler project on hold for a month so we could get this nailed out by Memorial weekend at the dunes, but we got screwed by Deaver and didn't get the rear leafs in time. Anyway, it's together now so here are some pics. I did all the custom design and fab, he did the other stuff like teardown and all that sh1t.
He had a nicely built '01 Sierra but got sick of blowing out the front end, didn't wanna solid axle it no matter how hard I tried to convince him, so he went for the upgrade. His old truck:
He got an '05 Ram 2500 CTD back in August, 5 days later it was up at the dunes for Labor Day weekend. It did great for a stocker but who wants a stock truck? He wanted to be able to haul across the dunes effortlessly at 60+mph and I wanted to make it happen. I talked him into a long travel suspension and 37s but he still wanted bigger. Then I found a great deal on some 40x13.5R20 XTerrains on here and it's been downhill ever since. Here's the specs:
-12" lift, all custom
-40" XTerrains on 20x10 KMC Diesels
-10" Full Throttle Coils, 12" travel Fox remote resi shocks, custom longarms and bracketry by BBA Fabworks
-8" Deaver leafs, 2" extended shackles, 14" travel Fox remote resi shocks, traction bar
-Axle trusses front and rear
-Drop pitman arm and sector shaft brace
-Custom trac bar and brackets
-Clocked t-case, new driveshafts, etc.
-A bunch of other little crap here and there
He's got a massive tuner, FASS, intake, stacks, and some other mods so it turns the 40s really well but it'll still get regeared before too long. It'd still blow most trucks out of the water.
We started on it the first weekend of May, got it on the road last Sunday.
How she sat the first afternoon
Stock coil next to new one and blingin shock
Then I figured I might as well blow a couple holes in the frame and start adding some reinforcement plates
Built up some adjustable UCA brackets out of 3/16" box and 1/4" plate
Then I had a cool picture in my head for the LCAs and tying everything together. Obviously beefiness is priority #1 but I can't just leave it looking plain either. I think the frame brackets turned out
I figure with an 8000 lb truck coming down on the front end some more reinforcement wouldn't hurt, and it makes it look a lot cleaner
The pics don't do it justice so far but oh well.
Old June 4th, 2008, 10:41 PM   #2
bbaXJ
Yooper In Training
bbaXJ's Avatar
Threw a truss on the front end:
I would've liked to make it wider but the little bit of extra strength probably isn't worth the tons of extra work in this application. It should still help strengthen the weak point in the middle a bit.
Might as well throw one of the sexy lady gussets in there
The drivers side was kind of a PITA. Because of the whole welding to cast issue I plated the bumpstop pad with 1/4" plate, welded it on, and drilled and tapped a couple bolts holding the plate to the cast. Then I welded the tube to the plate.....works for me.
Figured with 8k lbs coming down on the front end adding some strength to the knuckles wouldn't be a bad idea either. I plasma'd out some 3/8" plate to brace the inner Cs.
Meanwhile among other things my buddy stripped off the stock mounts and got some paint on the new frame brackets:
This is why it's going up another 4-6" (those are the 41s goin on my Jeep, not on the Ram):
Old June 4th, 2008, 10:44 PM   #3
bbaXJ
Yooper In Training
bbaXJ's Avatar
Plated control arm mounts and lower shock stud. I might do something to make this double shear, we'll see
I wanted to get rid of the cam bolt adjustment slot so the bushing had a good surface to sit against.
Then decided to go full crossover since the stock setup would've been hating life at that height with those tires. It's all 1.5" .25" wall DOM with 3/4" heims. I would've preferred TREs but there weren't any decent choices for the setup we had to work with and the timeframe we were trying to do it in. Still, for what it is I'm pretty happy how it turned out.
Had to chop off the panhard mount and clearance the coil mount for the new tie rod:
Also had to bend the tie rod to clear the diff cover/ring gear at full lock:
In hindsight I probably could've made the bends further out and not had to clearance the coil buckets as much but this works just fine.
Then it was on to control arms.
Bushing end:
All of em in place:
1.5" .25 wall uppers, 2" .25 wall lowers. I had to put a 10 bend in the uppers to clear the frame as the suspension cycles but I don't foresee any issues from it. I may brace the bends later on if I have any concern.
Old June 4th, 2008, 10:49 PM   #4
bbaXJ
Yooper In Training
bbaXJ's Avatar
I hate z-bend draglinks but I had to do something along those lines on this thing. The lower bend was necessary to clear the massive coils/buckets and I also used it to minimize the angle on the heim. The upper bend was required so the heim wasn't maxed on such a tall truck. Oh well, the .25 wall tube will do just fine.
I :heart: IROKs (my wheels/tires still)
Frame end panhard bracket built to match draglink angle. I still want to add a longitudinal brace but it's set besides that.
With all the important sh1t in place:
New beefier axle end panhard mount:
With the shiny new 40s on 20s:
Height reference.......I'm 6' tall
She's a wide one too:
For those that care, 41x14.5 IROK compared to 40x13.5 XTerrain with weight on it:
Me truck isn't small by any means (5" lift, 35s) but looks like a baby now:
Old June 4th, 2008, 10:52 PM   #5
bbaXJ
Yooper In Training
bbaXJ's Avatar
Funky sway bar links I came up with to make everything clear. I might add a diagonal brace later
4" extended and beefed shackles
Truss, trucker chick gussets, etc
Traction bar comes this week
DONE!!
She's a beast
Awwww how cute
Poserific
I know, not the typical rig most of us, myself included, would build. But it's made to be big, look good, and easily blast across the dunes at 60+. It'll do all that and more. Even if you don't like the style hopefully you can appreciate the fab work involved.
Old June 4th, 2008, 11:05 PM   #6
Stan
I got a gold chain
Stan's Avatar
Nice truck but HOLY FUCKING STACKS!!!!!!
Stan is offline   Reply With Quote
Old June 4th, 2008, 11:22 PM   #7
stevelknievel
Fuck Cancer
stevelknievel's Avatar
Send a message via AIM to stevelknievel
looks sick!!
stevelknievel is offline   Reply With Quote
Old June 4th, 2008, 11:33 PM   #8
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
I like!!!!!!!!!!!!
Old June 4th, 2008, 11:42 PM   #9
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
love it.
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old June 5th, 2008, 12:11 AM   #10
junk90xj
ALLPRO AUTO
junk90xj's Avatar
x2
but real good thought process and execution.
http://www.apalansing.com/
Old June 5th, 2008, 12:12 AM   #11
FQXehhhh
FQXehhhh's Avatar
I likey. Doesnt look like another lifted redneck truck. Great work man
FQXehhhh is offline   Reply With Quote
Old June 5th, 2008, 12:33 AM   #12
ddeadserious
ddeadserious's Avatar
Nice work and welds. Makes for a nice looking truck with some excellent fab work done. It should hold up well.
It does kind of dwarf your truck though
ddeadserious is offline   Reply With Quote
Old June 5th, 2008, 12:43 AM   #13
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
DAMNNN!!!!! I LIKE....A LOT!!!! Very nicely done!!
*2007 Rubicon
*2006 Duramax
Old June 5th, 2008, 01:42 AM   #14
MotoX5874
unbound
MotoX5874's Avatar
x2, they look mean as hell though, very big props on all the work, thing's a monster.
MotoX5874 is offline   Reply With Quote
Old June 5th, 2008, 04:27 AM   #15
sandman86
sandman86's Avatar
you got skill man ill give you that. bad ass truck!
sandman86 is offline   Reply With Quote
Old June 5th, 2008, 05:09 AM   #16
Jesse-James
Midwest Mudslinger
Jesse-James's Avatar
Awesome rig!
Jesse-James is offline   Reply With Quote
Old June 5th, 2008, 05:29 AM   #17
badazzamc
Get Some
badazzamc's Avatar
very nice, it looks like you guys have a lot of time into the truck, good job and it looks great.
Old June 5th, 2008, 05:53 AM   #18
ckhanna71
ckhanna71's Avatar
Wow, that is bad azzz
ckhanna71 is offline   Reply With Quote
Old June 5th, 2008, 06:14 AM   #19
KartRacer
Blowd up
KartRacer's Avatar
Nice. The fab work looks great.
Did those pretty welds come from that little Hobart?
Old June 5th, 2008, 06:28 AM   #20
_F_
Shama Lama Ding Done
_F_'s Avatar
Send a message via Yahoo to _F_
Does that thing spend time in Fenton? It looks real familiar. I think I've seen it on Oak Park. Nice truck and fab btw.
_F_ is offline   Reply With Quote
Tags
stacks r gay
Page generated in 0.47117 seconds with 84 queries
