outboard question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 3rd, 2008, 09:18 PM   #1
87'YJ
Jeeps, Journey and Jesus
87'YJ's Avatar
Default outboard question
Alright outboard guys, here's a question for you.
So I took the boat out sunday and had some problems with it. First time out all year, so that can be expected. I launched it, and then it wouldn't start. It would crank, but not kick. I sprayed some starter fluid in it, and finally it kicked over reluctantly (had to do it a few times).
We get out on the water and I punch it, gets right up to 60mph with no problem, but then immediately looses all power and stalls out. I have to start it out in the lake with fluid again. Now it would go in bursts of power, definitely seems like a fuel issue to me.
My guess is the fuel pump, and this boat has an interesting setup. The 2000 Johnson has a fuel/oil pump on the side of the motor, but the previous owner also installed an electric holley fuel pump under the seat which feeds into the one on the side of the motor. Before this pump is a "tank splitter valve" (I have two tanks and this valve switches between the two) which also may be starving the motor of fuel. I haven't yet had a chance to do any diagnostic on either pump, but I wanted to see if I am looking in the right place.
Ideas?
87'YJ is offline   Reply With Quote
Old June 3rd, 2008, 09:34 PM   #2
kickstand
circling the drain
kickstand's Avatar
Let me gues its a Ficht?
Old June 3rd, 2008, 09:58 PM   #3
87'YJ
87'YJ's Avatar
? What does that mean?
Old June 4th, 2008, 07:29 AM   #4
Disco Stocker
№ ℮ Ђ ώқ Θה ς├│ﺝ
Disco Stocker's Avatar
Ficht is a fuel injection technology that has not done to well in outboard motors.
http://findarticles.com/p/articles/m..._4/ai_61555469
Disco Stocker is offline   Reply With Quote
Old June 4th, 2008, 08:51 AM   #5
kickstand
circling the drain
kickstand's Avatar
x2. I can't recall the years of that brainchild. But I am guessing you have it.
I assume your boat is much to new to have the old shitty VRO pumps or whatever they were called that the late 80's johnrudes used.
I am not a fan, nor do I know much about the johnyrudes. screamandfly is probably your best bet at this poitn.
Old June 4th, 2008, 10:13 AM   #6
87'YJ
87'YJ's Avatar
Hmm. my motor is a 2000 Johnson 225 HO. So I guess it fits into that category, although, it hasn't had any problems till this time out. I had it out maybe 30 times last year with no issues.
I'm going to try and check all of the power to the electric fuel pump and switch today. If they are good, I'm not sure what my next step will be.
Old June 4th, 2008, 10:16 AM   #7
kickstand
circling the drain
kickstand's Avatar
screamandfly is your friend here, I am sure the problem is comon and can be quickly diagnosed.
Old June 4th, 2008, 10:24 AM   #8
87'YJ
87'YJ's Avatar
Yeah, i just posted over there. They were real helpful with my prop questions too. Its a great site for that stuff. Thanks man!
Old June 4th, 2008, 10:44 AM   #9
kickstand
circling the drain
kickstand's Avatar
Yeah those guys know their stuff for sure....there are some johnnyrude guru's over there that will probably have you diagnosed in no time.
Old June 4th, 2008, 08:54 PM   #10
87'YJ
87'YJ's Avatar
Well, that was a short search! I pulled off the fuel line after the electric pump and nothing came out, but the pump had power. It got extremely hot to the touch after about 3 minutes. I took it out and just got back from the store with another which I will hook up tomorrow!
Looks like that was the problem. There is no blockage at all between the tanks and the pump. We'll see tomorrow.
Old June 5th, 2008, 11:20 PM   #11
87'YJ
87'YJ's Avatar
It was the fuel pump! I installed the new one and ran the boat all night out in Erie! Perfect night, we went to Shooters too for all you guys that remember that place.
Old June 6th, 2008, 09:51 AM   #12
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
sweet..glad it worked out for you
Old June 6th, 2008, 09:56 AM   #13
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
seems weird you need two pumps i had problems with my stock pump keeping up on my boat and had to install a holly blue pump apperantly a stock pump made to run a motor at 5750 rpm doesnt like 8300 rpm. i would ask around and see if theres a way around running two pumps.
Old June 6th, 2008, 10:51 AM   #14
87'YJ
87'YJ's Avatar
I'll be honest, the mechanical pump on the motor may not be doing anything other than pumping oil. The PO may have bypassed it, but now that it all works, I don't feel like tearing it apart to see. I did get a holley blue as the electric pump.
Old June 6th, 2008, 10:53 AM   #15
kickstand
circling the drain
kickstand's Avatar
If it works it works right?
Old June 19th, 2008, 08:27 PM   #16
92comanche4x4
92comanche4x4's Avatar
I know the problem its A JOHNYRUDE lol im a merc guy
92comanche4x4 is offline   Reply With Quote
Page generated in 0.49048 seconds with 71 queries
