GM mechanic question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2006, 10:54 PM   #1
greenjeep
greenjeep's Avatar
Default GM mechanic question
I am getting an 98 Chevy malibu from a friend. It was in an accident on the LF side. The tire/rim is loose in the wheel well. Is there a common weak spot on these vehicles that breaks? Also what other vehicles can I get parts off of?
Thanks in advance,
Fred
greenjeep is offline   Reply With Quote
Old April 13th, 2006, 11:10 PM   #2
chris1044
chris1044's Avatar
malibu = alero = grand am - or atleast I'm 95% sure that it's the same.
As far as teh tire/rim being loose in the wheel well, it's probably a broken knuckle - I've seen a few of them break from simply hitting a curb with the vehicle
Old April 13th, 2006, 11:17 PM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Replace the entire knee unless you can tell exactly what it is. The knee consists of the hub, knuckle, strut and lower control arm. Any or all of those four parts could cause your problem.
Dumb question, but the lug nuts are torqued down right?
Old April 13th, 2006, 11:29 PM   #4
greenjeep
greenjeep's Avatar
OK cool. Yes the lugs are tight. It was hit in the LF. Was just asking mechanics that work on these cars everyday what the common failure was. I don't have alot of extra cash, so only the obvious things are getting replaced.
Old April 13th, 2006, 11:33 PM   #5
GreaseMonkey
Pew pew!
I worked on that platform alot when I was wrenching at Shelton Pontiac/Buick/GMC. Alot of those vehicles involved in that type of crash came from the body shop with a work order that generally said to replace the knee. That's at least what the insurance company wanted. On the ones I replaced, usually the knuckle was fine, but when I drove them in, the tire wasn't doing what yours is.
If going down the road your vehicle pulls or feels like the alignment is off, the strut is probably bent. The wobbling is either the knuckle or hub.
Old April 14th, 2006, 12:08 AM   #6
Mclovin
"The Situation"
Mclovin's Avatar
get it up in the air with a jack or hoist (< better)
then have a buddy shake the wheel and look to see what's moving separate from everything else...
Old April 14th, 2006, 09:16 PM   #7
greenjeep
greenjeep's Avatar
OK got the car tonight. It needs for sure a knuckle, brake hose, and a tire.
thanks again for the input, it looks like it might go back together pretty cheaply.
Fred
Old April 16th, 2006, 12:07 PM   #8
Sonicjay
Originally Posted by GreaseMonkey
I looked at that platform alot when I was changing oil at Shelton Pontiac/Buick/GMC.
Fixed it for ya :tonka:
Sonicjay is offline   Reply With Quote
Old April 16th, 2006, 01:31 PM   #9
GreaseMonkey
Pew pew!
That's two beers ya owe me now.
Page generated in 0.26696 seconds with 50 queries
