Warn 12k E-Winch Internals - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2008, 09:20 PM   #1
phazer42
I wheel, therefore I am
phazer42's Avatar
Default Warn 12k E-Winch Internals
Ok.... posted this on the Hummer forum but thought you guys might be interested to see this too....
this weekend we were at Drummond Island on a pre-run for this summers Hummer Club event.... it was a good time, however, at winch hill, after pulling 4 or 5 trucks up, I was unable to get my winch to work, it just clicked.... All the mean while, it kept geting harder and harder to pull the line out (I am running synthetic).... So, I knew when I got home I had a project infront of me....
Tonight I pulled the winch down and started to dissassemble it to find out the reason for the two issues.... so.... Here is what I found, not exactly what a winch gear should look like....
The end cap that has the free spool lever on it
The Motor End
The Drum - This is all rusty cause it had a steel line on it most of its life....
The damn allen bit I broke off - now another issue to deal with
middle planetary gear set
Bottom Planetary gear set
The gear set - Cleaned
Free Spool Lock - Hot it works
Basically it locks the planetary gear in place by putting a half-moon wedge in its way
Free Spool Lever Locked
Free Spool lever locked - the ring my thumb is on is the one that needs to spin freely to get the line to come out easy. This was, as you saw caked in 80% mud and 20% grease and it was tough to spin when I had it on the bench.
When I popped open the case for the gear set, out came about 12oz of water, so it obviously wasn't totally sealed as it should have been. I will be getting to the motor and drum later this week..... There is a good theory that my issue with the motor now is just the thermal over-ride.... but I have to get to that part next....
phazer42 is offline   Reply With Quote
Old June 2nd, 2008, 07:46 PM   #2
phazer42
phazer42's Avatar
Ok.... tonights project was to tear into the motor to ensure it was in good shape.... here is what I found.... please note this is the NEW version of the 12K winch. I believe this happened around the break of the century so if you have a 95 / 96 you likely have a different solenoid pack...
The motor assembly
Controller / Solenoid Pack
Internals of Controller / Solenod Pack
Winch Controller Plug Housing - Top
Winch Controller Plug Housing - Bottom
Motor Drive Shaft
Motor Assembly
Motor Top Cover Removed
Motor Brush Assembly Removed
Motor Brushes - Bottom Side
Motor - Windings / Shaft
Motor - Magnet Housing
Drum - Gear Housing Side
Drum - Driven / Motor Side
Drum Assembly
I don't have a press at my house, so I didn't take the drum apart... I don't know if I will or not, but thats where the brake is located inside the drum. As you can see the motor looks pretty good. I hooked it up to power and worked like a champ. So, it appears that the gear drive was my problem.....
I picked up my tub of water proof wheel bearing grease today so likely tomorrow I will start to put it all back together.... that is once I get that damn allen head out....
Old June 2nd, 2008, 07:53 PM   #3
Bishop
Bishop's Avatar
nice
Page generated in 0.32769 seconds with 32 queries
