poly bushings BLOW - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2006, 06:08 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default poly bushings BLOW
I am in the process of swapping a bunch of stuff around, and these poly bushings that I've been running are already wore out! Not even 3 years on them, and this thing is not a Daily Driver! So, can you get replacement rubber ones? And, any body know if you can get replacement anti-friction pads for between factory YJ leafs?
Old April 13th, 2006, 06:48 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
For the leafs you can buy a roll of liner, it kind of looks like garden edging. Where did you buy your polyurethane bushings from? Are you sure they weren't the greaseable kind of bushings (might not be polyurethane ones) either?
I've had rubber ones go bad within a few months, start squeaking and stuff like that. Switched to polyurethane ones and they were awesome.
Lifespan of polyurethane bushings are about five years, sometimes less, sometimes more depending on climate and use. Suspension design also greatly effects the lifespan. I'm assuming your talking about your Jeep, which has a modified suspension which is harder on the bushings, and think of all the crap those bushings get exposed to. Three years isn't that bad.
Page generated in 0.18507 seconds with 29 queries
