car dollie with a locker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2008, 08:19 PM   #1
luvitmyjeep
broken
luvitmyjeep's Avatar
Default car dollie with a locker
can i use a dollie to pull my tj with a locker in the rear ?
take off rear d-shaft?
put the t-case in N?
what is the best way to do this thanks. i'm in a time crunch!
luvitmyjeep is offline   Reply With Quote
Old May 30th, 2008, 08:25 PM   #2
MrGrey
propane evangelist
MrGrey's Avatar
neutral neutral
tires will squeal on corners.....
how far are you going? if it's a decent distance I'd pull the rear drive shaft
MrGrey is offline   Reply With Quote
Old May 30th, 2008, 08:27 PM   #3
luvitmyjeep
broken
from lake orion to the mounds
Old May 30th, 2008, 08:27 PM   #4
luvitmyjeep
broken
it's a detroit tru
Old May 30th, 2008, 08:30 PM   #5
MrGrey
propane evangelist
MrGrey's Avatar
manual or auto?
Old May 30th, 2008, 08:30 PM   #6
luvitmyjeep
broken
man
Old May 30th, 2008, 08:33 PM   #7
MrGrey
propane evangelist
MrGrey's Avatar
I think it should be ok in N N, but if you have any doubt you should pull the rear drive shaft
I pull my (ugly) buggy from davison to the mounds with a locked rear on a tow dolly with the rear drive shaft in and haven't had any issues.... but the distance is a lot less..
Heading out to the mounds challenge tomorrow?
Old May 30th, 2008, 08:34 PM   #8
luvitmyjeep
broken
hell yeah!
Old May 30th, 2008, 08:35 PM   #9
luvitmyjeep
broken
thanks a ton!
Old May 30th, 2008, 08:35 PM   #10
MrGrey
propane evangelist
MrGrey's Avatar
see ya there
Old May 30th, 2008, 08:41 PM   #11
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
No need to pull the Dshaft... TC and tranny in Neutral and you're ok. Lock makes no difference. BTW... I'm do this for a living.
Old May 30th, 2008, 08:56 PM   #12
Yeah, but short distance, right?
Otherwise, put the transmission in gear, not neutral. As a general rule, the oil slingers in the trans work off the transmission input shaft, on the output, so you don't want the trans spinning, which it can/will do, even when the t-case is in neutral, due to parasitic drag....
Old May 30th, 2008, 09:00 PM   #13
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Ummm not really.... Just got back from a 80 mile tow.... Why are you suggesting puttin git in gear? Care to explain.... I am curious as to your reasoning.
Old May 30th, 2008, 09:10 PM   #14
Jesse-James
Midwest Mudslinger
Jesse-James's Avatar
When I started towing with my dolly I had the same question since the manual says it needs to be in gear. The answer I recieved was that theres going to be a little parasitic drag through the drivetrain that will keep everything spinning. Slowly, but still moving. The slow turning with no fluid will burn up a bearing in the rear output shaft since the pump isn't turning. This is especially important with an auto even for short distances.
Bottom line is your manual says trans in gear and TC in nueteral.
Or just pull the shaft and be done with it.
Jesse-James is offline   Reply With Quote
Old May 30th, 2008, 09:12 PM   #15
ChadSmeltzer
ChadSmeltzer's Avatar
The manual says to put auto Jeeps in Park and tcase in N, and put manual Jeeps in gear with tcase in N
ChadSmeltzer is offline   Reply With Quote
Old May 30th, 2008, 09:20 PM   #16
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Hmmmm, never had a prolbem.
Old May 30th, 2008, 09:22 PM   #17
Edited the first post with the reasoning.
Old May 30th, 2008, 09:28 PM   #18
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
It seems to me that you would want the oil slingers thrown fluid around with anything in the trans spinning.
Old May 30th, 2008, 09:35 PM   #19
Jesse-James
Midwest Mudslinger
Also, if you do pull the shaft and still have a slipyoke a 1" slip fit PVC pipe cap works beautifully to plug the case.
Old May 30th, 2008, 10:16 PM   #20
scottie
Eye candy
scottie's Avatar
Another thing is, i assume the 231 has a true neutral position, so the Front driveshaft doesn't try and spin. Thats the only reason why i pull my rear shaft, is because a Samurai T-case doesn't have a true neutral and the front and rear shafts have to spin at the same speed.
LO to the mounds, i'd probably leave it in, but i have to pull mine because my front driveshaft is way out of balance.
Page generated in 0.31298 seconds with 82 queries
