VSS Wiring Or Output Information - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2008, 01:23 PM   #1
Stone
Ultimate Mall Wheeler
Stone's Avatar
Send a message via AIM to Stone
Default VSS Wiring Or Output Information
I'm Running a TBI 4.3L/700r4/231 from a 91 s10 blazer. I just installed a SYE among other things. Originally the the case had a vss with a magnetic pickup and two wire output that screwed in a hole about 3/4" in diameter in the tail housing. Now I have installed the plastic speedo gear instead of the metal one with the magnet. With the sye the tail housing has the large diameter hole for the normal jeep speedo. So without the vss I'm throwing code 24. Is there a larger diameter vss with the 2 wire type output? What do each of the 3 wires on the jeep sensor output? and can they be spliced to the two wires I have going to my computer?
So, basicly I'm trying to connect these two wires from my computer to a sensor that fits the same as this. Any ideas or info? TIA
Original GM vss(2wire)
Jeep VSS for sye(3wire)
Stone is offline   Reply With Quote
Old May 30th, 2008, 05:13 PM   #2
dodger889
dodger889's Avatar
OK from what I ca read the orange white and orange wires from the old sensor is what you need to conect. the other one should be nothing there. And it should matter which way you hook them up.
Tags
sye, vehicle speed sensor, vss
Page generated in 0.20451 seconds with 29 queries
