brake sliders - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2008, 12:57 AM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default brake sliders
so i finished my new rear axle but what would you recommend for greasing the sliders on the calipers? the drivers side is sticking so i need to get it movin. any suggestions?
nate4d is offline   Reply With Quote
Old May 30th, 2008, 01:04 AM   #2
FlatFender
Tap Tap Splat
FlatFender's Avatar
grease
Old May 30th, 2008, 01:06 AM   #3
nate4d
Gnarley Davidson
nate4d's Avatar
well i figured as much. just didnt know if anyone had any sort of special thoughts on a brand they found held up well to heat and water...
Old May 30th, 2008, 01:19 AM   #4
dodger889
dodger889's Avatar
actally anti sieze does a good job too especially with copper
Old May 30th, 2008, 01:24 AM   #5
OldSailor
AKA GreyShrink
OldSailor's Avatar
I'd wire brush the hell out of them first, to remove any possible rust and crud. I find that one of those small wire brushes on a Dremel tool does an excellent job.
Then I use Lubriplate to grease the sliders. Just enough to lube them - don't slather on so much that if flakes off and gets on the pads. Lubriplate works good if it gets wet (which is why it's used a lot in fishing reels).
OldSailor is offline   Reply With Quote
Old May 30th, 2008, 01:27 AM   #6
xjmichigan
xjmichigan's Avatar
x2 for Lubriplate
Old May 30th, 2008, 08:01 AM   #7
Sandals
Fucking Zen as Shit
Sandals's Avatar
Anti-sieze or i also have a bottle of napa caliper lube, works well
Sandals is online now   Reply With Quote
Old May 30th, 2008, 09:04 AM   #8
nate4d
Gnarley Davidson
nate4d's Avatar
thanx all. thats hopefully my last snafu
Old May 30th, 2008, 09:07 AM   #9
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
X2
I use this on my Fords all the time.
Page generated in 0.39639 seconds with 50 queries
