engine swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2008, 03:53 PM   #1
93XJcountry
Nothing Runs Like a Deere
93XJcountry's Avatar
Default engine swap
right now i currently have a I-6 in my truck with a e4od trans and i know that a 351w will bolt up but will a 302 bolt up?
93XJcountry is offline   Reply With Quote
Old May 29th, 2008, 04:35 PM   #2
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
i believe the 302 is on the same block as the 351, if not the same then similar, i could be wrong though.
why ditch the 4.9???
Bronco351 is offline   Reply With Quote
Old May 29th, 2008, 05:21 PM   #3
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
It will bolt up but you will need frame mounts as a V-8 is shorter than the I-6
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is online now   Reply With Quote
Old May 29th, 2008, 09:09 PM   #4
93XJcountry
it's been a long debate for me.
Old May 29th, 2008, 09:19 PM   #5
frdboy
frdboy's Avatar
Yes, 302 and 351w have the same bellhousing bolt pattern.
Old June 26th, 2008, 12:03 PM   #6
bronco91shee
bronco91shee's Avatar
Honestly, The 5.0 Isnt Any Better Than The 4.9. I Wouldnt Waste The Time To Swap It. Unless The 5.0 Has Got Some Money Into It. But If I Was Gunna Do Another Swap, It Would Be To Put A Windsor In B/c The Longer Stroke Will Be A Huge Help Off Road.
Just My .02 Cuz I Just Swapped My Windsor Out For A 460...more Low End Power
bronco91shee is offline   Reply With Quote
Old June 27th, 2008, 09:27 AM   #7
PavementPounder
PavementPounder's Avatar
I would leave the engine alone. Take the swap money and run on-board air up to a turret on the roof to power your paintball gun.
Old June 29th, 2008, 08:39 PM   #8
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
It wont sell good if you make the swap. You might have a hard time selling it if the numbers dont match.
Old July 14th, 2008, 02:18 AM   #9
Never_Evil
Unless your I6 is majorly messed up, keep it in the truck. I was doing the swap myself by taking out the 6 and putting in a hotter cam 302. IT WAS THE BIGGEST PAIN IN MY ASS TO DO. Like the others said, you will need special frame mounts that attach behind the "k-member" because the I6 mounts will need to be removed to clear the oil filter.
If the pain in the ass route wont dismay you from doing it, lets look it from the power/torque stand point. The I6 has longer push rods and have higher torque numbers at lower RPM's versus a short rod fast spinning high horsepower V8. When you are offroad, you need torque. Torque is the true power of an engine. Horsepower is the speed to which the torque is applied in a given time frame.
Fuel efficiency is roughly "ROUGHLY" 4 to 5 mph better than a v8. Feeding less cylinders and having the grunt to move the vehicle with relative ease makes sense. This of course depends on your driving style.
The only reason I wanted to put the V8 in my 4x4 was the ability to upgrade the horsepower and use it as a sleeper. I have since scrapped the project and found a newer truck with an FI 4.9L and it did great off road just crawling over obsticles and running through mud holes.
This is my thoughts on the subject and everyone is welcome to their own. BTW if you really want to make huge numbers and are stuck with the 6, put a TURBO on it and double your numbers!
Page generated in 0.24048 seconds with 50 queries
