Garage alignment. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2008, 10:02 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default Garage alignment.
Replaced tie rod ends last night, and I noticed I have some toe-out going on. Do I want out, in, parallel?
Old May 29th, 2008, 10:03 AM   #2
ddeadserious
ddeadserious's Avatar
You want 1/8 - 1/16 toe-in.
ddeadserious is offline   Reply With Quote
Old May 29th, 2008, 12:43 PM   #3
I'd go 1/8 to 1/4, with those particular tires. I set mine at 3/16th.
Old May 29th, 2008, 02:36 PM   #4
PavementPounder
PavementPounder's Avatar
Both sides of the garage should be parallel and the ends should be perpendicular to the sides.
Old May 29th, 2008, 03:30 PM   #5
Sandals
Fucking Zen as Shit
Sandals's Avatar
x2
Old May 30th, 2008, 06:15 AM   #6
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Yep, I do all of my vehicles this way, unless caster and camber are out.
Some do recommend toe out for fwd, but I do not agree.
RIP FULLSIZE4LIFE
Old May 30th, 2008, 06:18 AM   #7
clarkstoncracker
lol
Set it to 3/16ths. Much better then the 1 7/8ths out I had
Old May 30th, 2008, 08:20 AM   #8
84Scrambler
The ceiling and the floor should be parallel too.
Old May 30th, 2008, 08:29 AM   #9
It all depends on what you are trying to get out of it.
One thing people fail to realize sometimes is that since toe is usually measured at some point on the tire in distance, that you need more toe on bigger tires to keep the same relative amount in degrees.
For any car, it depends on what you are trying to achieve. Any of my performance cars, I set to some toe out, usually 1/16 to 1/8, vastly improves turn-in.
Tags
acid, cheap-ass
Page generated in 0.32950 seconds with 50 queries
