Ford explorer vs. Jeep Cherokee - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2008, 09:07 PM   #21
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
Originally Posted by xploder25 View Post
i cant make it to silver lake fathers day weekend, its the same weekend as my sisters graduation party.
grassman, are you running the stock motor with them 35's? what gears? my explorer wouldnt be able to touch your cherokee lol
I would like to see Grassman's rig do 60mph down the road.......
Although he will kick just about everybody's butt 0-5 mph at a an incline, while off camber.:tonka:
Old May 29th, 2008, 09:10 PM   #22
Soy_bomb
Web Wheeling!
Soy_bomb's Avatar
Originally Posted by jonzer12 View Post
An explorer has a pluses over a cherokee, a nice 8.8 rear,
a full frame, and the potential for a smallblock depending on year. Cherokee however is much lighter, smaller overall, and has solid front axle and probably better front suspension. If both are running the same size tires and have lockers in the same axles I would probably say the cherokee is better on paper but in reality it would probably come down to the driver.
X2
Soy_bomb is offline   Reply With Quote
Old May 29th, 2008, 11:06 PM   #23
Grassman
2jz specialist
Grassman's Avatar
yes, stock motor....4.56 gears
when i replace the fuel pump, then i will know better how it works
Old May 30th, 2008, 07:57 AM   #24
i'm partial to explorer over xj's for the simple fact that a cheap 4" lift can get you to clear 32-33's with no cutting, whats an xj need to clear a 32 with no cutting 6"?
Old May 30th, 2008, 08:51 AM   #25
What is this no cutting non-sense you speak of?
4.5" will clear 32's, but extended bumpstops will be necessary to keep them out of the sheet metal.
Old May 30th, 2008, 10:20 AM   #26
xploder25
All American Nightmare
xploder25's Avatar
yeah im with you there, i got 5" of lift (with the stock bumpstops) for about $250 give or take, i dont rub at all even with wheel spacers, and with the coils in the front and the TTB it rides awesome, i just need some new extended shocks
Old May 30th, 2008, 10:22 AM   #27
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
the TTB does ride very nice, it just has a bad rep off-road.
Bronco351 is offline   Reply With Quote
Old May 30th, 2008, 10:34 AM   #28
xploder25
xploder25's Avatar
yeah i know and i dont know why. its the perfect balance between strength and ride quality. Its in between an IFS and solid axle. You can get great articulation with extended radius arms and its handles and rides great. the only thing i dont like about it is the extra u-joint in the axle shaft and the toe in problem with the stock drop brackets from coil spacers.
Page generated in 0.22056 seconds with 47 queries
