Ford explorer vs. Jeep Cherokee - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2008, 08:55 AM   #1
xploder25
All American Nightmare
xploder25's Avatar
Question Ford explorer vs. Jeep Cherokee
i just got done building a 1991 ford explorer, 5" lift, 32" mt's, 3.73 with LSD in rear, 5 speed, etc. How do you think it would compare with a cherokee of equal size?
Old May 29th, 2008, 08:58 AM   #2
FORD FLARESIDE
Year 2 Griffins Travel
FORD FLARESIDE's Avatar
Be at Silver Lake Fathers day weekend, I have a cherokee with similar stats.
Lets fined out.
Old May 29th, 2008, 09:01 AM   #3
xploder25
xploder25's Avatar
whens fathers day weekend? if i can find the gas money ill make sure to be out there
Old May 29th, 2008, 09:03 AM   #4
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
It would probably depend, do you still have the TTB or did you do a SAS? and what exactly you mean by compare. whether it was a 2 or four door. etc...
Bronco351 is offline   Reply With Quote
Old May 29th, 2008, 09:15 AM   #5
jonzer12
An explorer has a pluses over a cherokee, a nice 8.8 rear,
a full frame, and the potential for a smallblock depending on year. Cherokee however is much lighter, smaller overall, and has solid front axle and probably better front suspension. If both are running the same size tires and have lockers in the same axles I would probably say the cherokee is better on paper but in reality it would probably come down to the driver.
jonzer12 is offline   Reply With Quote
Old May 29th, 2008, 09:16 AM   #6
xploder25
xploder25's Avatar
I have a four door with the stock TTB front Dana 35 with 3.73 gears. I still have the stock front control arms right now, i might be getting longer ones eventually, and the rear sway bar is taken out. I mean how do they compare in horsepower, reliability off road, articulation, axles, strength, etc.
Old May 29th, 2008, 09:18 AM   #7
xploder25
xploder25's Avatar
thats what i was thinking but i dont know anyone around grayling that has a cherokee that will put it up against my explorer
Old May 29th, 2008, 09:20 AM   #8
Bronco351
Powered by Ford
Bronco351's Avatar
Ford 4.0 (i assume you have?) 160hp 225 ftlb
Jeep 4.0 HO (as of 2004) 190hp 230ftlb
not that much of a difference
articulation the XJ will have the upper hand w/ the solid axle but also depends on what coils you have.
you can compare your Dana 35 TTB with the dana 30 with this thread, bunch of axle info.
Old May 29th, 2008, 09:24 AM   #9
xploder25
xploder25's Avatar
what does the older 90's cherokee's have for horsepower? im running a little more than 160 i think, i have a 2.5" exhaust, KKM cold air intake, i took out all the air conditioning, and i might be porting the heads.
Old May 29th, 2008, 09:24 AM   #10
FORD FLARESIDE
June 14th and 15th
Old May 29th, 2008, 09:24 AM   #11
Bronco351
Powered by Ford
Bronco351's Avatar
190 hp 225 ft/lb, not much difference again
but there is a weight diff between the 2, the xj is lighter i believe
Old May 29th, 2008, 09:26 AM   #12
xploder25
xploder25's Avatar
FORD FLARESIDE, ill try to be out there
Old May 29th, 2008, 09:31 AM   #13
xploder25
xploder25's Avatar
i think your right because explorers have a full frame and i think a little bit bigger and the XJ's are unibody
Old May 29th, 2008, 09:33 AM   #14
Bronco351
Powered by Ford
Bronco351's Avatar
yeah, a 4 door explorer has a 110" wheelbase and an xj's wheelbase is 101"
Old May 29th, 2008, 09:34 AM   #15
xploder25
xploder25's Avatar
i read that cherokee's are about 3000 Lbs. and explorers are about 3900 Lbs.
Old May 29th, 2008, 09:36 AM   #16
Bronco351
Powered by Ford
Bronco351's Avatar
sounds about right
Old May 29th, 2008, 09:41 AM   #17
FORD FLARESIDE
My XJ is just a $500 dollar beater, not anything too impressive.
Old May 29th, 2008, 01:27 PM   #18
xploder25
xploder25's Avatar
yeah i built mine from stock and have around $1,500 in aftermarket parts invested in mine, not including the $550 explorer i had to buy off ebay for the motor because i hydrolocked the original.
Old May 29th, 2008, 04:36 PM   #19
Grassman
2jz specialist
Grassman's Avatar
i will have mine there too i think, full size D44's w/ 35's
cherokees rule!
Old May 29th, 2008, 05:09 PM   #20
xploder25
xploder25's Avatar
i cant make it to silver lake fathers day weekend, its the same weekend as my sisters graduation party.
grassman, are you running the stock motor with them 35's? what gears? my explorer wouldnt be able to touch your cherokee lol
Page generated in 0.39460 seconds with 83 queries
