WTB 31 inch driveshaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2008, 08:44 AM   #1
JeepInABox
In too deep
JeepInABox's Avatar
Default WTB 31 inch driveshaft
I put a cj5 drive train in a cj7 and all of my shafts are too short.
Looking for a 30-31 inch running length rear driveshaft with slip joint.
DC joint is great but not needed
Old May 29th, 2008, 09:29 AM   #2
PavementPounder
PavementPounder's Avatar
I have a small collection of CJ driveshafts right now, so I'll see if anything is close.
Old May 29th, 2008, 09:09 PM   #3
JeepInABox
In too deep
JeepInABox's Avatar
PP any luck?
Anyone else?
Old May 29th, 2008, 10:50 PM   #4
PavementPounder
I have a couple normal fronts that are about the right length. They could get you functional until you get yourself a nice double-cardan setup. $20 for any of them.
I have one rear double-cardan rear that looks to be almost right on 31", but I wasn't really planning on selling that one. $50 if you want it. There's also the shaft currently in the back of my 85, which might be right. I wasn't dressed to crawl under and check it.
You can come take a look Friday after work if you like and we can measure the one in my CJ.
Old May 30th, 2008, 04:30 PM   #5
PavementPounder
I just rememebred there's one more rear shaft in the storage unit still attached to a CJ rear axle, which might be in the right ballpark for you.
Old May 30th, 2008, 09:22 PM   #6
JeepInABox
In too deep
JeepInABox's Avatar
Default Got one that will work.
anyone else got a cj driveshaft
Old June 12th, 2008, 11:03 PM   #7
JeepInABox
In too deep
JeepInABox's Avatar
All of PP shafts were close but no winner
Still need a 30 7/8 running length slipshaft
Anyone?
Old June 12th, 2008, 11:29 PM   #8
PavementPounder
The problem is that he needs a double-cardan yoke that will fit a Dana 20 rear output. He had a QT front yoke that was the right size, but the wrong spline for the Dana 20 rear output shaft.
What fits a 1310 double-cardan and has the right spline count? An Xj 231 front yoke?
Old June 16th, 2008, 08:38 AM   #9
JeepInABox
In too deep
JeepInABox's Avatar
Anyone?
Looking for a
1. 31 shaft with slip joint
2. a yolk to fit the dc joint on a xy front shaft to a dana 20 transfercase rear output spline.
Old June 17th, 2008, 02:06 PM   #10
shredder70
Chillin with the top off.
shredder70's Avatar
I think i have one. I have a qt transfer case with one still installed.. It has a amc 20 offset rear if that will work.
shredder70 is offline   Reply With Quote
Old June 17th, 2008, 02:39 PM   #11
JeepInABox
In too deep
JeepInABox's Avatar
PM sent
Page generated in 0.19567 seconds with 56 queries
