motorcycle road test questions. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 28th, 2008, 11:36 PM   #1
stevelknievel
Fuck Cancer
stevelknievel's Avatar
Send a message via AIM to stevelknievel
Default motorcycle road test questions.
i dont have a book and i want to take my road test asap (riding with just a permit is getting old) can anyone tell me what they require you to do? this is going to mandate whether i take my GL1000 or my sisters rebel
stevelknievel is offline   Reply With Quote
Old May 28th, 2008, 11:50 PM   #2
PavementPounder
PavementPounder's Avatar
Take the Rebel.
Old May 28th, 2008, 11:51 PM   #3
stevelknievel
Fuck Cancer
Originally Posted by PavementPounder View Post
Take the Rebel.
thanks man, i figured that a smaller bike would be better, i might take my cousins honda whatever too.
but can anyone tell me what they require you to do on the course?
Old May 29th, 2008, 12:14 AM   #4
jeepguy74
jeepguy74's Avatar
stoping without skidding with only rear brake slolum through cones acelerate then stop turns without putting foot down....ect
they give you more room for bigger motor in bike but you also have to be nimble on that bike..go with the rebel bigger displacement smaller type bike...but i think the rebel would be a good choice as it is a nimble bike...also you can go to sos and they will tell you what you wil have to do ...
Old May 29th, 2008, 12:29 AM   #5
medicbear
Ax me bout ebonics!
medicbear's Avatar
or find a place that rents mopeds for the test you think im joking but there are and i actually watched a guy who looked old school biker fail on it... you have to swerve and u turn without touching the ground....
medicbear is offline   Reply With Quote
Old May 29th, 2008, 12:41 AM   #6
stevelknievel
Fuck Cancer
hmmm idk if i can get my sisters rebel by friday so i may take my cousins little 600 or 650. seems like itll be easier
i was gonna go to SOS to ask but i can think of better things to do with the hour and a half of my life they waste
Old May 29th, 2008, 06:20 AM   #7
rallyemore
Snowman
rallyemore's Avatar
Send a message via AIM to rallyemore
1. Left hand u-turn (20 ft)
2. Accelerate (15ish mph) and stop before a line BOTH BRAKES
3. Slalom 5 cones 15' apart 1.5' off center
4. um... ah fukc it.
Here's the link.
http://www.michigan.gov/sos/0,1607,7...7444--,00.html
rallyemore is offline   Reply With Quote
Old May 29th, 2008, 06:33 AM   #8
Icemanii
GLFWDA Land Use Committee
Icemanii's Avatar
Not sure why I am being this nice but here goes.
Test is a total of 10 scored areas, some done at the same time. There is a total of 6 events to score on, and no one area can fail you. Automatic failures are:
1] Dropping the motorcycle during the test.
2] Committing any unsafe act on the motorcycle
3] Failure to follow instructions
As for the tests themselves:
Event 1 Shifting, sharp turn, and stopping
Start at the 'T' in first gear, upshift to 2nd, downshift to 1st, make a sharp left turn thru the corner, back up to 2nd, back down to 1st as you stop with your front tire in the box. Keep your speed down, brake before the sharp corner and look thru it, not at the lines.
Event 2 Cone weave and U-Turn
Start at the 'T', go to the left of the first cone, right, etc., thru the 5 cones, make a 180 Deg turn and head back to the U-turn box. Enter the U-turn box straight in on the right side, and make the left hand U-turn. Use the friction zone of the clutch and your rear brake to control speed in the cone weave. On the U-Turn box, as soon as your front tire enters the box, turn the handlebars and get back out - don't go to the back of the box.
Event 3 Turning Speed Selection
Start at the 'T', make the 90 deg. left hand curve at speed. Stay in first gear, enter the curve at about 8 to 10 MPH, and gently accelerate thru the entire curve, exiting about 12 MPH. Stay within the lines.
Event 4 Stopping Quickly in a straight line
Start at the 'T', on signal accelerate to about 12 to 15 MPH. On signal stop in a straight line. (Return to start point when told). First gear here as well. Accelerate quickly and stabilize your speed. On signal stop as quickly and safely as you can. Try not to skid. If you overrev the motorcycle, stop anyway, then adjust the throttle.
Event 5 Stopping Quickly in a curve
On signal accelerate to about 12 to 15 MPH into curve. On signal stop in within the lines. (Return to start point when told).First gear here as well. Accelerate quickly and stabilize your speed. On signal stop as quickly and safely as you can. Try not to skid. Start near the right side line, and enter the curve early staying within lines. That will make this close to a straight line stop.
Event 6 Swerve
On signal accelerate to about 12 to 15 MPH. On signal swerve in the direction indicated by the tester thru the lane avoiding the obstacle line.First gear here as well. Accelerate quickly and stabilize your speed. Do not try to guess which way to swerve, stay straight down the middle of the lane until signaled.
Other thing the grade you on is Overall control through out the test. This is things like Skidding, stalling, looking at your controls. etc.
My pointers? Except for the first test where you have to shift, stay in 1st gear throughout the test. Don't hot dog, maximum speed you need to read would be 15 MPH, higher speeds just make the test harder. You can pass the test on any size motorcycle, depending on your skill level. However, it is easier on smaller displacement bikes.
These are just my thoughts on it. I am sure there are some experts on the site here who may give you different advise, go with what you want. Good luck.
Icemanii is offline   Reply With Quote
Old May 29th, 2008, 06:45 AM   #9
dodger889
dodger889's Avatar
Here is the other thing find out where they test usealy a parking lot. and they noraly would have the course layed out so you can see it. Take a bike so some slow trail runs That way you can get a feel of what the course is like to you. Good Luck
Old May 29th, 2008, 06:50 AM   #10
Icemanii
Icemanii's Avatar
A lot of community colleges have the course laid out. Some places that test will not let you practice at their location.
Old May 29th, 2008, 07:05 AM   #11
Oscoda02Ranger
Cops Don't Like Mud!
Oscoda02Ranger's Avatar
Send a message via AIM to Oscoda02Ranger
If your in romulus take the test at biker bobs. they rent a buel blast that is pretty easy to do the test on.
Its on telegrah between eureka and pennsylvania.
Oscoda02Ranger is offline   Reply With Quote
Old May 29th, 2008, 07:23 AM   #12
curt1656
Praise the lowered
curt1656's Avatar
You don't need a permit. If the cops try to pull ya over just open up the throttle! You'll be famous! Can even be on the news if ya time it right! If you do take the test wheelies and stoppies really impress the instructors. And extra brownie points if ya don't wear a sissy helmet. (of course I'm just kidding)
Old May 29th, 2008, 12:29 PM   #13
stevelknievel
Fuck Cancer
thanks all. isnt biker bobs thing like 350 bucks??
and haha thanks for the info curt, i spit milk on my comp screen
Old June 5th, 2008, 11:20 PM   #14
Oscoda02Ranger
No you can take the test there too but its through BLANZY.
I'm doing mine through
www.stroiaschoolofdriving.com
Page generated in 0.31047 seconds with 64 queries
