AW4 "Manual" conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 28th, 2008, 10:01 AM   #1
General Lee
Slice of Starsage Anyone?
General Lee's Avatar
Send a message via AIM to General Lee
Default AW4 "Manual" conversion
I know this has been discussed everywhere, but I wanted some opinions...
I'm debating making the mods to the AW4 to control the shifting. Here is the article:
http://www.jeepforum.com/forum/showthread.php?t=273048
Similar kits sell for $90-$200, but it costs like....$15 in parts, so I'd rather do it myself.
I haven't been able to find good answers as to whether this modification will cause a greatly shortened life for the trans or not.
Also, what are the different signals sent for reverse, neutral, or park (every write-up seems to only list the forward gears)?
Other opinions?
Thanks!
-Jim
General Lee is offline   Reply With Quote
Old May 28th, 2008, 10:30 AM   #2
FlatFender
Tap Tap Splat
FlatFender's Avatar
thats because all the writeups still use the factory shifter for those. there is actually a linkage used to shift the tranny into reverse, neutral, park. the forward gears use the computer.
Old May 28th, 2008, 10:46 AM   #3
General Lee
Bhumz...I guess I'll have to keep the factory shifter too...
Does anyone know how much current those solenoids pull?
Does whatever forward gear you're in effect anything when you shift into reverse?
Thanks!
Old May 28th, 2008, 11:01 AM   #4
General Lee
Also, nobody mentions the other wires. Are they left connected and untouched?
Old May 28th, 2008, 12:43 PM   #5
General Lee
Is this bad for the trans?
Does cutting the 12V line from the trans effect anything???
Old June 2nd, 2008, 07:41 PM   #6
Mulder
Jeeper
Mulder's Avatar
you won't have a reverse signal
Mulder is offline   Reply With Quote
Page generated in 0.28969 seconds with 41 queries
