Sas On Gmc Canyon - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 25th, 2008, 08:30 PM   #1
spidergear
who used all the TP
spidergear's Avatar
Default Sas On Gmc Canyon
i got my mind set to sas my canyon but im stuck on what kind of stering box should i use just a plane 70s chevy box. what is most common on s10 sas? anything will help
spidergear is offline   Reply With Quote
Old May 25th, 2008, 10:24 PM   #2
GetItOffroadGMC
GetItOffroadGMC's Avatar
Are the Canyons rack and pinnion? If not then use your box and find the right pitman arm.
GetItOffroadGMC is offline   Reply With Quote
Old May 25th, 2008, 10:26 PM   #3
spidergear
who used all the TP
spidergear's Avatar
ya its a rack and pinion
Old May 26th, 2008, 10:24 AM   #4
spidergear
who used all the TP
spidergear's Avatar
no one else can shoot me there two cents
Old May 28th, 2008, 08:24 PM   #5
knaffie
knaffie's Avatar
s10 uses s10 or astro box, i have two of them here if you ever come this way
Old May 28th, 2008, 10:40 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i've never seen any colorado/canyons modified in such a way. get pics of your progress as i'm interested to see how this goes. as for the steering concern, your probably going to have to use a chevy steering box, idk how much room you have or how the linkage will have to be run, but you could set everything up for a crossover setup as it's much better then the push-pull setup GM used from the factory.
Old May 28th, 2008, 10:48 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
hes talking about rack and pinion steering..
Old May 29th, 2008, 06:46 AM   #8
knaffie
knaffie's Avatar
Read what he wrote............"i got my mind set to sas my canyon but im stuck on what kind of stering box should i use just a plane 70s chevy box. what is most common on s10 sas? anything will help" My post advised him of what we use on S10 SFA conversions, as he requested. What exactly are you referring to? Are you suggesting he leaves the r&p steering? that would be interesting!
Old June 25th, 2008, 12:04 AM   #9
bbc_77_j10
bbc_77_j10's Avatar
Send a message via MSN to bbc_77_j10 Send a message via Yahoo to bbc_77_j10
heres an sas colorado
i like the front drive shaft
bbc_77_j10 is offline   Reply With Quote
Old June 25th, 2008, 12:16 AM   #10
bbc_77_j10
bbc_77_j10's Avatar
http://www.coloradofans.com/forums/v...p?f=55&t=61192
this is a build up of another one i found while googleing and damn what a fabricator, unless its a kit and if its a kit i want one for my canyon
Old June 26th, 2008, 10:17 PM   #11
chevotass
chevotass's Avatar
i wouldnt worry about the steering box right away. I would get the axle and suspension built and then work on the steering. it might not work out in the build what looked like it would on paper.
Old June 27th, 2008, 12:02 AM   #12
Mclovin
"The Situation"
Mclovin's Avatar
yep i missed that
Old June 27th, 2008, 04:05 PM   #13
jeeperbrian
GLFWDA member
is your truck yellow? i think ive seen it around acouple times
Old June 27th, 2008, 04:08 PM   #14
spidergear
who used all the TP
spidergear's Avatar
ya it is yellow
Old June 28th, 2008, 12:00 AM   #15
cruzer72
cruzer72's Avatar
Originally I was gonna use a 79 f150 gear box on my s-10 swap. Cause it mounts on the outside of the frame and the pitman arm faces forward.
cruzer72 is offline   Reply With Quote
Old November 9th, 2010, 09:30 AM   #16
Sfa_Colorado
RIDGEOFFROAD.COM
Sfa_Colorado's Avatar
Default My conversion
Sfa_Colorado is offline   Reply With Quote
Old March 20th, 2011, 01:08 AM   #17
Sfa_Colorado
RIDGEOFFROAD.COM
Use the yota box that's what I have
Old March 22nd, 2011, 12:53 AM   #18
dragtruk
Questionable..
dragtruk's Avatar
Send a message via AIM to dragtruk
i dont suggest drive out at that pit
dragtruk is offline   Reply With Quote
Old March 25th, 2011, 05:09 AM   #19
Sfa_Colorado
RIDGEOFFROAD.COM
You can when you have promission to be back there
Old March 1st, 2013, 07:17 PM   #20
sas canyon curt
Default i have a sas canyon
i have a sas canyon look at my pics
sas canyon curt is offline   Reply With Quote
Page generated in 0.58503 seconds with 83 queries
