Need help picking front axle for my willys - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 22nd, 2008, 02:38 PM   #1
robbie thomas
robbie thomas's Avatar
Default Need help picking front axle for my willys
Hello to everyone,i am a newbie to the 4x4 seen.i have bought a 52 willys pickup and am starting a build.i don't want an axle that hangs out a mile.right now i am at the point of selecting a front axle but don't know what to use the original is 58" wide.i can use a ford 9" in the rear(i have left over parts)i have a cj wide track front 58" wide but fear it is too light.i also have a gmcorp10bolt but needs shortened. i have a budget for this year and don't want to break the bank
planned so far
sbc with 700r4-208
-33-35" tires
4-6" lift spring under
any help is greatly appreciated
robbie thomas is offline   Reply With Quote
Old May 22nd, 2008, 05:09 PM   #2
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
with the tire size your gonna run the cj axle should be just fine, and since you already have it it's all the better!
71jeepster is offline   Reply With Quote
Old May 22nd, 2008, 05:20 PM   #3
Well, If you want to use a 9" rear, then might be better to figure your width options there, first, then find a front to match.
Personally, I'd run a dana 44, with that application. The 30 might just be a little lightweight.
If you don't want too wide, then something like a wagoneer front axle, and run the ford spindles to get the 5 on 5.5 pattern. Those waggie axles are around 59-62" wide, IIRC, depending on year..
Obviously, a matched set from a bronco would work, but not sure what kind of radius arm bracketry will be in the way of your spring under perches.
On a budget, see if you can find something in the 3.73-4.11 range stock, so you don't have to regear. Might be worth a couple hunderd more on the axle price, rather than pay $500+ for new gears and setup...
Old May 22nd, 2008, 05:40 PM   #4
http://www.greatlakes4x4.com/showthread.php?t=90723
Old May 22nd, 2008, 09:04 PM   #5
robbie thomas
thanks for the all responce.i tryed to make my post as informative as possible but have failed and missed a few things.i have a complete 85 k-5 for a donor.i want to robb all my goodies out of it.the axles would serve my purpose.the rear would fit near perfect but the front is way to wide as stated.should i shorten the front axle or run the cj i have?if i run the cj front i have a 9" to match.if i run the 10 bolt it will all match but need to shorten it.
Old May 24th, 2008, 11:49 PM   #6
PavementPounder
PavementPounder's Avatar
Exactly how wide is the 9" WMS-WMS?
Cutting down a 10-bolt is not worth it. Run the CJ D30 front. Or, if the 9" is 58-60" WMS fully assembled, an uncut Wagoneer front D44 will be a nice match from a width perspective and you won't have to deal with any custom length shafts if you break something.
Old May 25th, 2008, 04:07 AM   #7
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Get a D44 out of a Scout. If your lucky you can get a D44 front and rear for a good price and they are pretty narrow. not sure exactly how narrow but Jeep guys have been swapping them into jeeps for years.
Tags
acid
Page generated in 0.35567 seconds with 44 queries
