dim headlight on a 95 saturn. Helps please - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2008, 11:22 PM   #1
Shotgun
I only wheel with boats.
Shotgun's Avatar
Default dim headlight on a 95 saturn. Helps please
I have a 95 sc2 it has a dim headlight on the driverside. The bulb is good, Im guessing there is a voltage drop somewhere. What the hell does this connect to or do they join togther and go into a the same headlight module or are they seperate?
Thanks
Old May 22nd, 2008, 06:20 AM   #2
GetItOffroadGMC
GetItOffroadGMC's Avatar
Id start with the ground.
GetItOffroadGMC is offline   Reply With Quote
Old May 22nd, 2008, 08:29 AM   #3
linuxrick
linuxrick's Avatar
Send a message via Yahoo to linuxrick
x2
check the connectors/harness for corrosion, never worked on a saturn before but are those popup kind? maybe hard to find if so.
linuxrick is offline   Reply With Quote
Old May 22nd, 2008, 05:44 PM   #4
Shotgun
Shotgun's Avatar
connectors are good, I just replaced both popups on the car. this had this problem before I bought the car, A friend of mine owned it for the year before me and just never screwed with it other then checking the grounds.
Page generated in 0.18568 seconds with 35 queries
