Line locks as cutting brakes, opinions needed. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2008, 02:14 PM   #1
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Default Line locks as cutting brakes, opinions needed.
Im soon going to be upgrading to a twin stick T-case for my TJ and figure that while Im at it install some kind of cutting brake so i can lock up just the back brakes and do front digs if needed.
Now ive seen a few different setups and was wanting peoples opinions. First off should i run electric or manual locks. Manual locks are very simple, nothing really can break on them, but to mount them where you want will require lots of brake line bending into the cab on the Jeep. I could use plastic brake, which would be easier to run, but its also easier to damage. Electric locks are remote and can be mounted inline where you want them, however the soleinods can get mighty hot in left in use for more than a minute(or so others say).
The next thing to consider is to use just 1 line lock to control both rear wheels or have 2 locks and be able to lock up each rear wheel independently. Being that my White TJ is not really a competition rig I really dont think 2 locks are all that necessary, they double the cost of everything,
and double the chance of something going wrong, but they also offer more choices.
Another option i was thinking about was using a regular cutting brake. This also is a very simple way to lock up the rear, but required a lot of extra work and time and wouldnt really fit in the interior of my Jeep.
Oh and incase anyone is wondering, i dont really have to worry about damaging my drive train. The front is a HP 44, with 35spline ARB locker and dana 60 outers, the rear is a Solid Axle HP SF 60, with 35 spline ARB, alloy shafts, and disk brakes with parking brakes, and the T-case is a STak. Only thing that might be weak is in the front. 30 spline outer stubs and factory u-joints. If those break ill convert to 35 spline outers and CTM or Longfield u-joints.
I'm the man in White.
Old May 21st, 2008, 03:13 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
or buy a cutting brake
i have heard the electric line locks get very warm after extended use
Old May 21st, 2008, 03:23 PM   #3
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
real cutting brakes are cheap and easy to install...just do one of those...you can get a single or twin stick brake...just look for sandrail parts
Old May 21st, 2008, 03:37 PM   #4
Sandals
Fucking Zen as Shit
Sandals's Avatar
If your looking for a cutting brake, buy a cutting brake.
If you want a line lock definatly get a manual one, i prefer the Mico Lever lock
http://www.mico.com/products/displaysubinfo.php?id=43
Old May 21st, 2008, 03:57 PM   #5
I'd agree, get a cutting brake if thats what you want. Ease of use will be better (unless you need to shift, steer, and brake....).
But, another creative post to pimp your shiny parts, very clever
Old May 21st, 2008, 04:14 PM   #6
Pokerob
hug life
Pokerob's Avatar
do cutting breaks work on a rear welded diff?
i was thinking of running duel VW golf hand breaks for cutting, but im really not sure if that would even work on a welded diff, im guessing not.
Old May 21st, 2008, 04:15 PM   #7
insaneoffroader
insaneoffroader's Avatar
the only problem i see w/the cutting brake is every time you want to use it you will have to unlock the the rear ARB. i know its not that hard to do but just a thought .
insaneoffroader is offline   Reply With Quote
Old May 21st, 2008, 04:19 PM   #8
MidMichxj
Wrenchin for a livin
MidMichxj's Avatar
Why not just use the parking brake to hold the rears?
You are not looking to hold the rears individually are you?
MidMichxj is offline   Reply With Quote
Old May 21st, 2008, 04:23 PM   #9
hosejockey4506
Visiting Admin
haha where do you get this info
Old May 21st, 2008, 04:59 PM   #10
Pokerob
hug life
Pokerob's Avatar
because the parking break holds both,
from what ive read cutting holds one each side
Old May 21st, 2008, 05:37 PM   #11
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Yes, cutting brakes technically are supposed to activate one brake or the other to assist in a tight turn. If you have a locking differential it would have to be unlocked to be a "cutting" brake.
That said, on tight turns I can put my rear drive line in neutral, turn to lock, and hold my foot on the brake while giving it gas. The front tires will overcome the brake and the locked front will drag the welded rear as it turns.
JcrOffroad
Zoom Zoom!
Old May 21st, 2008, 05:43 PM   #12
Christmas Cookie
cutting breaks will not work on a welded or locked diff...duh...
Old May 21st, 2008, 05:48 PM   #13
Skooter_Built
im still considering it as an option, but with a full center counsol, parking brake, manual shifter...there is little to no room. I think ill give an electric line lock a try, there not very expensive.
yes im very proud of being a college student that works very hard and buys nice things. Shame on me:miff: jelious
not enough holding power, remember parking/emergency brakes arnt ment to completly stop your vehicle like your regular brakes
Old May 21st, 2008, 06:04 PM   #14
Well, they work, just they lock both tires. So having a single action cutting break to lock the entire rear axle is a decent option.
Here's a topic I started about it a while back on Pirate:
http://www.pirate4x4.com/forum/showthread.php?t=671967
General concensus is that its still quite effective.
I know the people I have discussed this with who have used line locks do to this didn't like the level of coordination to do it. With a cutting brake, its a single action, pulling the level moves fluid, so engages the brake. With line locks, you need to either activate the lock, then hit the brakes, or hit the brakes and then activate the lock, depending on the method you are using.
I plan a single level (single output) brake in my Jeep. With the automatic, I can modulate the rear brakes with one hand and steer with the other.
Old May 21st, 2008, 06:21 PM   #15
insaneoffroader
i'm not saying it don't work. its just not a "cutting" brake by the definition most people know
Old May 21st, 2008, 06:28 PM   #16
Christmas Cookie
ya..but thats not a cutting brake...thats having independent brakes...completely different in my book
Old May 21st, 2008, 06:33 PM   #17
Mclovin
"The Situation"
Mclovin's Avatar
didnt you post a while back that your parents paid for your off roading habits ??
not talking shit my parents paid for my stuff through college..
Old May 21st, 2008, 06:40 PM   #18
Clearly, but when you go to purhase something like this:
you call it a cutting brake, even if you aren't controlling the rears independantly. So, if I install it my Jeep, I would still call it a cutting brake, even though I have a welded diff.
I miss my sand rail.
Old May 21st, 2008, 06:43 PM   #19
DCX
out to lunch
DCX's Avatar
Hello the one in your pic still controls the rears separately so it is a cutting brake!
DCX is offline   Reply With Quote
Old May 21st, 2008, 07:04 PM   #20
*sigh*
So, is it a cutting brake if you bleed and block one port and run the other to a combined rear line?
Yes.
Is it independant control?
No.
If you used half of a dual lever cutting brake, do you magically rename it to something else?
If you ran each output seperately to the left and right calipers on a welded axle, is it independant lockup? No (although stresses the axle shafts...)
Whats with the web wheeler cutting brake name police in here?
Tags
acid
Page generated in 0.47026 seconds with 83 queries
