tj bolts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2008, 12:13 PM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default tj bolts
looking to replace all the bolts that hold my front and rear axles in
looking for lengths and threads. most of mine are either broken or the threads are f'd.
FRONT
axle shock bolt size:
UCA frame bolts size:
LCA frame bolt size:
UCA axle bolt size:
LCA axlre bolt size:
REAR
UCA axle bolt size:
LCA axle bolt size:
any help will be appreciated!
nate4d is offline   Reply With Quote
Old May 21st, 2008, 02:47 PM   #2
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
go to lowes with some of your old nuts and bolts and pick up that you need. Just make sure you get grade 8 or at the bare minimum grade 5. Yes you'll end up paying a lot more, but better to be safe than sorry. What ever you do, make sure to get 1 or 2 of everything for trail emergencys, and antiseeze is your friend.
if i remember correctly LCA's are close to 5/8" for the frame and axle
and UPA's are 9/16" or 1/2".
I'm the man in White.
Old May 21st, 2008, 02:55 PM   #3
liv2mx
i like jungle gym's.
liv2mx's Avatar
shock bolts 1/2 inch
i belive the stock lower arm bolts were metric on mine. 12mm bolt. if not 9/16. the stock arm bolts are taperd also.
Old May 21st, 2008, 03:13 PM   #4
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
FRONT
axle shock bolt size: 1/2 13NC 1.5" grade 8
UCA frame bolts size: Not sure
LCA frame bolt size:M14x2.0 120MM grade 10.9
UCA axle bolt size: M10x1.25 75MM grade 10.9
LCA axlre bolt size:M14x2.0 120MM grade 10.9
REAR same as front
UCA axle bolt size:
LCA axle bolt size:
90% sure
Page generated in 0.17370 seconds with 35 queries
