Transfer case flip? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 19th, 2008, 09:46 PM   #1
thrill20
thrill20's Avatar
Default Transfer case flip?
Ok, I've searched google, pirate, ih8mud, and here and haven't been able to find an answer.
I planned on running a full ford drive train in my FJ40. 351 or 302ho, C6, and Np205. I've stumbled accross a pretty good deal on axles, but the front is a passenger side drop. What options do I have if I want to keep my C6? I've searched for somekind of flip kit, but haven't found anything. Can I use a chevy Np205, or are they totally different? I don't really want to start from scratch on my drive train as I have the 5.0/C6/205 already, and I'm debating on a fuel injected 351.
I hate to pass up these axles, but are there any good options that are not rediculously expensive.
Thanks,
Will
thrill20 is offline   Reply With Quote
Old May 19th, 2008, 09:48 PM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
all np cases use the same bolt pattern. You'll just have to make sure the input shaft will work
Old May 19th, 2008, 09:52 PM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Nope.
If you find a 6 bolt round pattern chevy 205 and then swap in the 31 spline ford 205 input that should bolt up (might have to redrill some holes)
Old May 19th, 2008, 09:57 PM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
what are you saying nope to??? that all np cases have the same bolt pattern? Or that you will have to make sure the input shaft fits??
just wan't to figure out exactly what i said was wrong, or is all of it lol??
Old May 19th, 2008, 10:03 PM   #5
thrill20
thrill20's Avatar
I did just come accross a data sheet on high impact that tells the difference. Well, sorta. If I find the correct chevy 205, I should be able to change the input. They both have 6 hole bolt patterns, but it doesn't say if they are the same.
Thanks for the replys though.
You got one of them sitting around Adam?
Old May 19th, 2008, 10:12 PM   #6
Jeepaholic
Jeepaholic's Avatar
They all don't have the same pattern, most old chevy's use a figure 8 pattern.
Nope, I don't usually don't carry that chevy crap :tonka:
Old May 19th, 2008, 10:14 PM   #7
thrill20
thrill20's Avatar
Understandable.......
Old May 19th, 2008, 10:19 PM   #8
bigcountrysg
Countryboy
bigcountrysg's Avatar
I have a chevy 203 sitting in my barn. It is a passenger side drop, I can check the bolt pattern for you. As well as the spline count.
bigcountrysg is offline   Reply With Quote
Page generated in 0.21828 seconds with 47 queries
