Tire balancing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2008, 05:52 PM   #1
zoomin0074
Default Tire balancing
I had my tire balanced at a belle tire and this thing has so much weight it is horrible.. What are my options.. Should I take it somewhere else? Should I have the rim balanced first before putting the tires on then have it balanced?
zoomin0074 is offline   Reply With Quote
Old May 17th, 2008, 06:03 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
Epic fail, you have a bent rim most likely. Take it back and tell them to redo it.
Old May 17th, 2008, 06:09 PM   #3
zoomin0074
there was a different tire mounted on this rim (same size and brand just different) and was balanced fine on the inside of the rim only. I dont think the rim is bent and this tire has never seen pavement.
Old May 17th, 2008, 06:33 PM   #4
dodger889
dodger889's Avatar
here is something else to look at measure from the rim out to the little line (seam) and make sure the tire is seated on the rim right front and back.
Old May 17th, 2008, 06:36 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
use bead weights that go inside the tire...countless guys i've heard run them on the highway with virtually no vibration...idk sounds like a good idea to me.
Old May 17th, 2008, 06:39 PM   #6
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
do the bb trick with the tires
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old May 17th, 2008, 06:46 PM   #7
BlueydChevygal
BlueydChevygal's Avatar
Send a message via Yahoo to BlueydChevygal
Hubby works at Discount Tire. He says take it to a place with a road force balancer, (Discount Tire) and that will tell you if it is a bad tire or a bad wheel. From there they can tell if the wheel is bent or if its a bad tire. If its the tire, maybe where you bought it from could send it back. Good Luck!!
BlueydChevygal is offline   Reply With Quote
Old May 17th, 2008, 07:22 PM   #8
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
x2, take it to a place with a road force balancer, and they should be able to get it to balance right or, tell you if something is bad, and looking at that picture that is freakin ridiculous, who ever did that should now that something was obiously not right.
Old May 17th, 2008, 08:38 PM   #9
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Have them break it down and spin the tire 180 on the wheel and rebalance. If that doesn't help, it's most likly a bad tire.
Old May 17th, 2008, 09:17 PM   #10
jeeperbrian
GLFWDA member
why are there sticky weights on the outside of the rim?
Old May 17th, 2008, 09:53 PM   #11
zoomin0074
Thats what im wondering.. I was told the manager was the one who actually balanced it.. The worker couldnt figure it out.. I guess I will try discount tire and see what they say.
Old May 17th, 2008, 10:08 PM   #12
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
they need shot for doing that shit
Old May 17th, 2008, 11:50 PM   #13
badazzamc
Get Some
badazzamc's Avatar
thats scary that a manager added that much weight. I really want to know how some of those guys ever get a job in a tire shop
Old May 18th, 2008, 12:13 PM   #14
Denton
Brush Yo Teeth!
Denton's Avatar
X2
This actually works
It is worth a try!
Denton is offline   Reply With Quote
Old May 18th, 2008, 05:58 PM   #15
zoomin0074
I did tell the guy to do it that way cause they had already mounted/balanced them but had the whitewalls out.. I took them back and told them black walls out and if you need to rotate the tire on the rim until the balance is better.. I think I just got unlucky.. I'm going to take them to discount tire on Monday and see what they say.
Originally Posted by Denton View Post
X2
This actually works
It is worth a try!
Old May 19th, 2008, 03:37 PM   #16
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
WTF?????? If I had seen that I would have lifted that entire combo up at beat the manager with it, then make him eat all those balance weights.
x2 on "epic fail"
Old May 19th, 2008, 08:40 PM   #17
LuckyCharm4x4
LuckyCharm4x4's Avatar
Send a message via AIM to LuckyCharm4x4 Send a message via Skype™ to LuckyCharm4x4
I work at Belle and I'd never do that if it's more than like 6 oz. off. that looks like it's 20+ oz. you could have them match mount it. it's like they are saying with the 180 the tire, but it matches the heaviest part of the rim with the lightest part of the tire. it's worth a shot. but if you say the rim is ok, then the tire is probably just shotty!
~Bry
LuckyCharm4x4 is offline   Reply With Quote
Old May 20th, 2008, 07:19 AM   #18
BlueydChevygal
Did u do anything with it yet? Wondering what they said!!!
Old May 20th, 2008, 11:16 AM   #19
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
every time I see that pic i get pissed off. x2 what's going on with this.
Old May 20th, 2008, 11:24 AM   #20
Flexin' XJ
Flexin' XJ's Avatar
My 93 chevy with those wheels always had tons of weights. One would not balance and it was bent, but even the new one was horrible.
Flexin' XJ is offline   Reply With Quote
Page generated in 0.32608 seconds with 83 queries
