Electronic Quadrajet - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 16th, 2008, 12:18 PM   #1
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Question Electronic Quadrajet
I got a carb of from a mid 80's chevy truck with a 350 that was removed last week. I would like to use it on my amc 360. Can/will this carb. work without the electronics attached?
thanks
RIP FULLSIZE4LIFE
Old May 16th, 2008, 12:29 PM   #2
dodger889
dodger889's Avatar
that should be tbi and not a carb. If I remebr right that is. after about 1990 and newer they where all some sort injection system.
Old May 16th, 2008, 12:44 PM   #3
junk90xj
ALLPRO AUTO
junk90xj's Avatar
yup thats tbi injection not a carb.
http://www.apalansing.com/
Old May 16th, 2008, 12:57 PM   #4
SHARPMACHINE
F-U-CANCER!!!
Ohhh shoot, mid 80's not 90's thanks
RIP FULLSIZE4LIFE
Old May 16th, 2008, 08:33 PM   #5
dodger889
dodger889's Avatar
Even mid 80 most were fuel injection of some sort. does this have 4 bolt or does it have 3 bolts to fasten it down??
Old May 17th, 2008, 09:25 AM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
they started the TBI on the trucks in 87 just FYI. 86 and down were carbed and used the electronic q-jet. no you can't run it without the electronics as it will run very poorly.
Old May 17th, 2008, 01:46 PM   #7
SHARPMACHINE
F-U-CANCER!!!
This is not a tbi unit! I am wondering why/what it would take to use it???
RIP FULLSIZE4LIFE
Old May 17th, 2008, 01:53 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
need the computer and wiring from any vehicle that had that carb...you will also need a computer controlled big cap HEI. not the remote coil version used in 87 and later apps.
Old May 17th, 2008, 01:54 PM   #9
SHARPMACHINE
F-U-CANCER!!!
I found this thread yesterday, no replies yet but looks promising???
http://pirate4x4.com/forum/showthread.php?t=666481
RIP FULLSIZE4LIFE
Old May 17th, 2008, 01:56 PM   #10
Nuggets
I fix stuff!
Nuggets's Avatar
If it is a Q-jet and it has a big blue plug in the top with some wires in it, it will run ok. The plug part is a fuel metering solinoid that the ECM used to regulate regulate fuel mixture based on oxygen sensor readings. This system worked poorly at best for mixture control. You can run that carb on a stock motor without any problems. You probably have a big obnoxious throttle position sensor on that thing too, take it off and throw it away.
I wouldn't expect too much from this carb. I would just use it until a non polution Q-jet comes your way or you find something different.
Old May 17th, 2008, 01:59 PM   #11
SHARPMACHINE
F-U-CANCER!!!
Thanks guys,
Another question, I have a quadrajet that was not working well the last time someone tried to run it, so could I use parts from the older one to eliminate the electronic metering control???
RIP FULLSIZE4LIFE
Old May 17th, 2008, 02:14 PM   #12
Nuggets
I fix stuff!
Nuggets's Avatar
Originally Posted by SHARPMACHINE View Post
Thanks guys,
No. Your best move is to rebuild the older unit. Q-jets are decent performance carbs, it will be worth your time.
Tags
quadrajet
Page generated in 0.25940 seconds with 59 queries
