Should i use Radiator stop leak? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 13th, 2008, 05:33 PM   #1
mxdude27
Default Should i use Radiator stop leak?
Hi i have a decent size leak from the radiator on my 94 bronco my dad went to autozone to pick up some chit and he brought home so alumaseal radiator stop leak... now i have heard that this does more harm than good sometimes with certain brands would this benefit me for a permanit fix or will it clog up other important stuff thanks
mxdude27 is offline   Reply With Quote
Old May 13th, 2008, 05:44 PM   #2
bigcountrysg
Countryboy
bigcountrysg's Avatar
The only time I used that crap is when I am traveling and it is an emergency fix. If you are not stuck somewhere don't use it. Go to a radiator shop and have the radiator repaired or buy a new radiator.
bigcountrysg is offline   Reply With Quote
Old May 13th, 2008, 05:45 PM   #3
montecarlo33
The Violator
montecarlo33's Avatar
X2
Old May 13th, 2008, 08:48 PM   #4
firehawk
Live Action!
firehawk's Avatar
If it is damaged from being hit or something similar just have a rad shop fix it. Should be like $50
Or if it leaking from breaking down, replace it.
Old May 13th, 2008, 09:45 PM   #5
mxdude27
well its either that or the hoses bc its a 94 and i think those hoses havnt been replaced yet
Old May 13th, 2008, 11:27 PM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
no!
fix he problem.
http://www.apalansing.com/
Old May 13th, 2008, 11:48 PM   #7
mxdude27
thanks guys should i take the beast into a radiator shop to have them check all the lines or just throw in a new radiator... n if i get a new rad. what brand n should i go with the same dimensions as my oem one thanks
Old May 14th, 2008, 03:25 PM   #8
Smiley23
Smiley23's Avatar
BTW, I worked for a company in highschool where I made Rad Solder (stop leak). Main chemicals were 300 gallons of water, 150lbs of barmiculate clay, and 150lbs of sawdust.
Smiley23 is offline   Reply With Quote
Old May 14th, 2008, 08:59 PM   #9
jeepers48
jeepers48's Avatar
You have 2 or 3 options
fix the leak only. And maybe next month you have another leak?
recore: they use your tanks and install new core rows(lines)
new radiator or reman.
Or if you want your engine to run cooler, order an after market Aluminum radiator.
if you have limited funds, there nothing wrong with having a radiator recored.
A rad shop will install one, just like the one you already have. They'll look up yours in the book an order it or already have one in stock.
oem rads really wont matter what brand but alum rads.......Theres more than a few. Google it to see what brands are out there or one of the guys on the board well rattle off a few for you.
Best thing for you to do is shop around and get price quotes. Ive had numerous rads done in the past and never had a problem with a rad shop backing the work they did on my radiators/fixing one again that they fixed a few months earlier.....for free.
jeepers48 is offline   Reply With Quote
Page generated in 0.39311 seconds with 50 queries
