Couple west side trails for you guys. - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Land Use > GPS tracks and trails
GPS tracks and trails 4x4 trails and destination coordinates
Old May 12th, 2008, 10:09 AM   #1
Foamer
Foamer's Avatar
Default Couple west side trails for you guys.
They are in kmz format for a direct import into google earth, but can be converted to other formats here: http://www.gpsvisualizer.com/convert
The Cedar Creek Trail system (Twin Lake, MI):
http://jasonlebrasseur.com/trails/Ce...ek%20Trail.kmz
White River trails (in and around Greenwood, MI)
http://jasonlebrasseur.com/trails/Wh...r%20Trails.kmz
Enjoy! More will be coming as I travel them. And the above files are not all the trails in the given area, just the ones I traveled so far. If there is a very short offshoot from a main trail, it usually means that I came upon a gate or sign stating that the trail was closed, or there was an obstacle that I could not make it past.
Foamer is offline   Reply With Quote
Old August 18th, 2008, 09:18 PM   #2
webqaz
No luck loading these into Google Earth I get an error that says: "Parse error at line 1, column 49: syntax error"
webqaz is offline   Reply With Quote
Old August 20th, 2008, 11:24 AM   #3
4x4_Liberty_06
4x4_Liberty_06's Avatar
TTT - Same problem here.
4x4_Liberty_06 is offline   Reply With Quote
Old August 20th, 2008, 02:30 PM   #4
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
fail
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old August 30th, 2008, 01:05 AM   #5
KartRacer
Blowd up
KartRacer's Avatar
hmm
Old August 30th, 2008, 06:42 AM   #6
bud_light_zero200
bud_light_zero200's Avatar
Send a message via Yahoo to bud_light_zero200
It be cool to have a site to where you just type in the zip code where you want to wheel and it shows all the trails in the area.
bud_light_zero200 is offline   Reply With Quote
Page generated in 0.28563 seconds with 41 queries
