Staun Beadlocks - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 10th, 2006, 04:44 PM   #1
victorymike
Geocache Addict
victorymike's Avatar
Default Staun Beadlocks
Has anybody seen the (relatively) new Staun Tire Beadlocks? They work with any rim. From what I can tell they are basically a tube insert that is pressurized to (a minimum of 2psi) more than the tire itself. You have to drill a hole for the 2nd valve stem. They look tough to assemble but bulletproof when installed. Even allows run-flat limping without rim damage. Anybody have any idea how much they cost? I can't find prices anywhere on the web.
(Made by the same manufacturer as Staun Tire Deflators.)
victorymike is offline   Reply With Quote
Old April 10th, 2006, 05:15 PM   #2
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Give Mike @4x4rockshop.com a ring (205) 942-9999. He sell's Staun beadlocks.or call David @ northridge4x4.com a call or you might even try backcounrtyoffroad.com(BDR and Lowlock) they might be able to get them for you.
Old April 10th, 2006, 05:16 PM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
They are around $1000 for a set of 4. they are a take off from the "swedish beadlocks" I believe the have a kevlar lining.
Old April 10th, 2006, 06:17 PM   #4
victorymike
Geocache Addict
Thanks very much for the info guys. You 2 are totally awesome!
Old April 10th, 2006, 06:31 PM   #5
Bones
Bones's Avatar
I think HJ runs them... and he still blows beads....
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 10th, 2006, 07:27 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I think were about 280 each when I looked into them.
Old April 10th, 2006, 10:17 PM   #7
Tab
Tab's Avatar
Plus a few guys that have them on Pirate say they still lose beads. It gets pushed around in there by the tire bead under extreme load and they move and lose air. Kinda pricey to not be a positive lock. And they are from overseas somewhere. I though australia but killerb may be correct in sweden.
Old April 10th, 2006, 11:20 PM   #8
Grandman
do i look old !
Grandman's Avatar
I thought they looked like a great idea , sounds like that not that effective though ! :gman:
Page generated in 0.26351 seconds with 47 queries
