4X4 not engaging - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 14th, 2005, 12:54 PM   #1
highrider
Send a message via Yahoo to highrider
Default 4X4 not engaging
How do I test to determine if it is my vacuum shift motor that is causing my 4X4 not to engage? I shift into it at the transfer case and things are good at the rear wheels, but the front isnít engaging.
If it is the vacuum shift motor failing, I see a popular approach to repair is the installation of a Posi-lok kit. Thoughts?
Thanks!
highrider is offline   Reply With Quote
Old November 14th, 2005, 04:31 PM   #2
shawn
Resident HVAC/R Jambi
shawn's Avatar
Crawl under your heep and check it out. That is the ONLY way you will find out if it is operating. It is real easy to take out. And once it is off the axle you can see if it is moving when you pull that shift lever. As long as you have a good shift actuator, it usually works fine. But, other alternative (besides teh posi-lock) is to just stack a bunch of washers behind the shift fork and leave it engauged. It works, and it's cheaper.
Old November 14th, 2005, 06:35 PM   #3
Chop
Mischievous Badger
Chop's Avatar
make sure there is vac through the lines running to the diaphram on the front axle. if there is no change when you shift from 2 hi to 4wd them the vac switch on the Tcase is bad.
Old November 15th, 2005, 09:25 AM   #4
highrider
Cool...I will check it out and post back.
Old November 16th, 2005, 01:50 PM   #5
davidbrady
just pack washers behind the shift fork, easy fix, done in 10 minutes, and for less than $1
davidbrady is offline   Reply With Quote
Page generated in 0.19432 seconds with 38 queries
