f350 drag link/sas???!HELP! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 11th, 2008, 01:33 AM   #1
sandman86
sandman86's Avatar
Default f350 drag link/sas???!HELP!
ive been looking and been all over trying to find the adjuster sleeve and the short end(pitman arm side) for the drag link on an f 350 4x4, so i can finish the SAS on my f150 thats been sitting for 3 years.
acording to the @SS hats at autozone, murrys, and pepboys ford never made a 4wd f350...thats what they told me...winners.
any who any ideas?....HELP!!!
does something for a f 250 or 150/bronco fit??
i have the long end...that was easy to find.
sandman86 is offline   Reply With Quote
Old May 11th, 2008, 01:34 AM   #2
gas_hog99
gas_hog99's Avatar
Send a message via Yahoo to gas_hog99
Did you try givinf it sime beer?
gas_hog99 is offline   Reply With Quote
Old May 11th, 2008, 01:39 AM   #3
jeeperbrian
GLFWDA member
, that might work
Old May 11th, 2008, 05:50 AM   #4
sandman86
sandman86's Avatar
Originally Posted by jeeperbrian View Post
, that might work
na i tried drinking with it,even yelling and making fun of it...nothing works...
i just need this part so i can get the mudder f#!ker on a trailer and at my house so i can finish the darn truck...
btw stats on the truck...
92 f150 sas..ish,d60rear, 78bronco d44 with 3/4 ton outers,cage offroad radius arms, 6in bds springs,3in body lift(comin off), carbed 80s 351bored .030 over 11:1,built aod trans.
need to find manual shift bronco t case (non slip yoke), get drive shafts made, resto body, rewire truck...yadayadayada...
Old May 11th, 2008, 07:24 AM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
look on www.rockauto.com
@clarkstoncracker
Old May 11th, 2008, 07:32 AM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
MOOG Part # ES2012S More Info {Adjusting Sleeve}
Frt Strg; LH; Pitman Arm To Connecting Tie Rod; 4WD
Frt Strg; LH; Steering Arm To Steering Arm; 4WD
Frt Strg; RH; 2WD; Crew Cab, Ambulance
ACDELCO Part # 45A0425 More Info {#88910259}
ROD,STRG LNKG INR TIE -; LEFT HAND; w/4WD; 1" - 18 THREADS
Not sure if these are the parts you're looking for, but I did a quick search at rockauto for a 94 F350 w/diesel engine. Plenty of 4wd listings there.
@clarkstoncracker
Old May 11th, 2008, 09:18 AM   #7
kickstand
circling the drain
kickstand's Avatar
I bet the dealer does not sell the parts of have the part numbers.
Old May 19th, 2008, 04:00 AM   #8
sandman86
sandman86's Avatar
Default found...
so i skiped a day of sleep(work nights you'll understand then) to go to the stealership and get the parts...and get other junk done
got the short drag link end...
the adjuster sleeve is no longer produced but the parts manager was able to locate one for me, should get it some time this week...
thank you for your help
...and smart assism
Old May 20th, 2008, 08:54 PM   #9
agfordman
agfordman's Avatar
I got all my stuff through auto value, I used a 1987 drag link, and it worked great
agfordman is offline   Reply With Quote
Old May 22nd, 2008, 04:56 AM   #10
sandman86
sandman86's Avatar
hey could you get me a pic of your track bar mount? i need an idea how to make mine...thanks
Old May 22nd, 2008, 06:08 PM   #11
agfordman
agfordman's Avatar
pm sent!!!
Page generated in 1.61114 seconds with 56 queries
