Common Problem with f150? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2008, 08:54 PM   #1
FQXehhhh
FQXehhhh's Avatar
Default Common Problem with f150?
I have a 2003 f150 supercrew 4x4 that i've had minimal problems with. I've finally surpassed the 100k mark and as i expected, an issue has occurred. When i put it into reverse it makes a loud clunk noise, then when i start backing up it sounds like two people going at it on an old bed. The sound is coming from the back somewhere and it sounds like the drive shaft. When it's in drive there are no problems until about 40mph and the steering wheel starts to shake. It's not a violent shake but enough to where i can feel and see it. I had a problem a while back when my parking break basically grenaded inside the drum, but we just removed that and problem free until now. Now i hear that my friend's mom, who has the exact same truck as me, is doing the same thing. Anyone experience this problem? Before i start tearing into things or take it to the shop
FQXehhhh is offline   Reply With Quote
Old May 7th, 2008, 09:26 PM   #2
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
i would start with u joints/pillow bearing/driveshaft inspection look for any play or obvious wear, for the steering wheel shake hows the alignment, tires in good shape no uneven wear, or missing wheel wieghts?
broncobuddha is offline   Reply With Quote
Old May 7th, 2008, 09:31 PM   #3
buddha
playing life by 'ear'
buddha's Avatar
x2 (u joint)
Old May 7th, 2008, 10:08 PM   #4
FQXehhhh
FQXehhhh's Avatar
front end is tight and tires are in great shape. My brother suggested power washing my rims out to make sure no dirt is making it shake but i already did that. The sound make me think it is the u joint but i got under there and tried to see if the drive shaft had an play, none. ah i hope its nothing expensive -->dealer ship <--- me
Old May 8th, 2008, 06:41 AM   #5
broncobuddha
Starting over
when you check the drive shaft was it in nuetral? if not there can be enough bind in it to keep you from finding the play
Old May 8th, 2008, 08:45 AM   #6
barry1me
Just another day
barry1me's Avatar
my 99 F150 was similar when the Ujoints needed replaced
barry1me is offline   Reply With Quote
Old May 8th, 2008, 08:51 AM   #7
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
X a billion, u-joint
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old May 8th, 2008, 08:54 AM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
U-joints don't necessarily have to have play in order to make noise.
Old May 8th, 2008, 10:40 AM   #9
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
U-joint, U-joint, U-joint, U-joint...........................................U-joint.
Probably the one on the back of the rear driveshaft, "but change them both on the rear driveshaft"
If you have a short wheel base Ford truck, or Bronco, they will go bad.
Change them before the Drive shaft drops and you have to have that replaced as well.
Old May 8th, 2008, 09:12 PM   #10
FQXehhhh
FQXehhhh's Avatar
Thanks for the replies. My instincts were the u joints but i wanted to make sure there wasn't a common serious problem. Thanks guys
Old May 9th, 2008, 07:09 AM   #11
76 high boy
serious business
76 high boy's Avatar
myne did this in my truck. i checked and no play. drivn down the road and there goes my rear shaft. destroyed it. had to find another one.
76 high boy is offline   Reply With Quote
Old June 26th, 2008, 12:26 PM   #12
bronco91shee
bronco91shee's Avatar
the only way to really find the u-joint, IMO is to pull the shaft out and rotate all of the ujoints all the way. probably are binding, which you will never find with the ds in the truck. it would cause all of your sypmtoms. but it also could be bearings in the rearend, but i rule that out b/c you say it happens right when you put it in gear. that means something is loading and moving without the wheels moving yet. that rules alot of stuff out. i bet a 100$ that its seized ujoints
bronco91shee is offline   Reply With Quote
Old June 27th, 2008, 08:05 AM   #13
bj house
bj house's Avatar
slip splines are known to stick slip and cause a loud thump when coming to a stop or going from rev to fwd etc.
Solution it usually to pull apart the slip and regrease with the appropriate lube. . Although U-Joints are an easier check.
Old July 6th, 2008, 10:21 PM   #14
FQXehhhh
FQXehhhh's Avatar
I know this thread is a little out dated but it did end up being the u-joints. Man, i wish i would have taken pictures. The rear u-joints were so bad the needs were either deteriorated or welded together. It was bad but after a few hours and curse words i got the problem fixed. Thanks for the replies.
Page generated in 0.27110 seconds with 65 queries
