oil pressure - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 9th, 2006, 11:31 PM   #1
user name
keep your stick onthe ice
user name's Avatar
Default oil pressure
well i got my truck all put together. Took it for a ride sat night all back roads cuz its not plated and such everything went fine. no problems. Earlier today i decided on a little longer drive that included some highway when i got back to my parking lot i stopped in drive and the oil light came on. took it out of gear and pressure went right up to normal. i then held it at about 2500rpm in park for a few seconds and the gage started to move around iratically then i shut it off because it isnt making any noises yet. ok and hear is some stuff from putting it in it had some really nasly oil in it when i got the engine valve train noises went away just with the oil change. the temp gage is not working and it did smell a little warm. im back at school and cant play with it again for a week but im hoping bad sender. my other thoughts are it got to hot and the oil got thin or the oil is not draning back to pan fast enough to get picked back up (clogged drain back holes from the nasty oil) any other thoughts that i can check out next weekend?
ok i think that makes more sence now
Old April 9th, 2006, 11:55 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
I'm confused about your post...and I don't mean your truck.
Old April 10th, 2006, 03:48 PM   #3
noodles
give 'er sh*t ay?
noodles's Avatar
check your oil pressure with a manual gage. ive switched senders in my truck and its something in the dash to where when i come up on a idle it will kick the light and drop the gage.
Old April 11th, 2006, 11:10 AM   #4
SS
Bananarama!
SS's Avatar
Obvious but you'd be surprised how many people make this mistake...
Be sure you have enough oil in the engine...
You may be right about the clogged system from the nasty oil
Run up to murrays and buy an oil pan gasket and some oil system flush. Run the flush through your engine (the 5 minute stuff by Eagle) and drain your oil. Then drop the oil pan and clean out all the sludge and debris that's now resting on the bottom of your oil pan.
You'll be surprised by what will come out.Total cost is something like 12 bucks
-Jer
Old April 22nd, 2006, 04:33 PM   #5
Toivo
Feel lucky?
Toivo's Avatar
Default Annoyances
Ok craig. Seriously. Dude. Stop nitpicking all the little details of everything you own. Not to be an asshole, and not that I really care, but you are always so hellbent on oil pressure, its annoying. You swapped in an engine that is bone stock with over 100k miles. Its not going to be A-1. It runs good, and HAS oil pressure. Stop worrying about such little details "like it seems a little low". Irrelevant-not brand new stuff. Seriously.
Old April 22nd, 2006, 04:37 PM   #6
PavementPounder
PavementPounder's Avatar
Yeah, don't pay any attention to the oil light that is programmed to let you know when there isn't enough oil pressure to operate the motor.
Old April 22nd, 2006, 04:46 PM   #7
Toivo
Feel lucky?
Toivo's Avatar
Default still
:miff: self...ok good call, still, its not a award winner. Its still got 100k, and the motor came out of a truck used ONLY for plowing U.P. snow. And the owner is notorious for um...not treating engines and trannys as intended. One instance...parking lot...10mph...dropped into park w/o use of brakes Oh..lol...i forgot...state street here in BR..2wd low racing ppl..."engine has rev limter for reason" cough cough smoke clouds
Old April 22nd, 2006, 07:18 PM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
You are both :gman:
Old April 22nd, 2006, 07:34 PM   #9
Toivo
Feel lucky?
Toivo's Avatar
Default Go...
Im an old man? Go smoke a carton of newports
Old April 22nd, 2006, 09:40 PM   #10
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
No, you are LAME.
Old April 23rd, 2006, 06:51 PM   #11
user name
user name's Avatar
not smoke couds and the large amount of aduse is all the more reson not worry about hmm the little red light is on thats not a good thing dumb ass o ya and jon your a douche and on a side note put in a mechanical gage and its good enough for me 15ish in gear hot idle and 50 running down the road.
Old April 24th, 2006, 11:58 PM   #12
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I would bet that the min spec for hot in gear is much lower than 15. You would be surprised at what the specs read for min oil pressure at ldle...I have seen some specs as low as 5 at idle is OK.
Page generated in 0.28436 seconds with 59 queries
