SOLD - CJ Con-Ferr lift shackles, 2.5" (CJ rear and YJ all) - $50/set - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2008, 07:22 PM   #1
PavementPounder
PavementPounder's Avatar
Thumbs up SOLD - CJ Con-Ferr lift shackles, 2.5" (CJ rear and YJ all) - $50/set
1 pair measures 6.5" hole-hole. The other pair are about 6". Both pair were originally CJ rear shackles, but the spring width is the same as YJ.
If you don't like the gay-ass paint job on the one pair, talk to HawksCJ5. :tonka: They have a "gold" finish underneath. The other pair is unpainted.
These shackles have welded crossmembers, which means they are for use with flat-faced poly bushings. Using them with beveled bushings will create a very unsafe driving condition.
$50 for the set of four. No trades.
SOLD.
PavementPounder is offline
Old May 7th, 2008, 09:23 PM   #2
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
umm they were rust before...homo! and free bump for ya
hawkscj5 is offline
Old May 19th, 2008, 08:32 AM   #3
kickstand
circling the drain
kickstand's Avatar
Just curious, what makes that a rear shackle and how does a shackle know the difference?
kickstand is offline
Old May 19th, 2008, 09:00 AM   #4
PavementPounder
Because the bushing will not reach the shackle mating surface if you put these on a CJ front leaf. CJ springs are different widths front/rear.
You can run these at any corner on a YJ.
Old May 19th, 2008, 09:53 PM   #5
kickstand
circling the drain
kickstand's Avatar
Roger that.
Old May 22nd, 2008, 05:55 AM   #6
hawkscj5
hawkscj5's Avatar
Originally Posted by pumpshop4 View Post
These will match the other rears I bought from you. I will paint them black to cover the gayness .
man wtf is up with you and the gayness thing?
hawkscj5 is offline
Old May 30th, 2008, 09:52 AM   #7
PavementPounder
Updated. Now a set of 4.
Old July 24th, 2008, 12:37 AM   #8
Jesse-James
Midwest Mudslinger
Jesse-James's Avatar
Would you split them up? I could use the 6" pair.
Jesse-James is offline
Old July 29th, 2008, 03:46 AM   #9
Jesse-James
Midwest Mudslinger
Guess not, thanks anyway.
Old August 2nd, 2008, 01:22 PM   #10
PavementPounder
Bump.
Old August 9th, 2008, 09:54 PM   #11
PavementPounder
SOLD.
Tags
cj, cj5, cj7, shackle
Page generated in 0.20223 seconds with 56 queries
