1990 Bronco $1300 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2008, 11:03 AM   #1
udjlax
udjlax's Avatar
Send a message via AIM to udjlax
Default 1990 Bronco $1300
1990 Ford Bronco, Eddie Bauer, Fullsize, 5.0L/AOD/bw1356 (push button). odometer says 400 miles, but best guess is 200,400 miles. The engine runs strong. new-ish trans, i recently swapped in an AOD from a f250 it had about 80,000 miles on it when pulled. it works fine, but shifts a little hard, i think there may be a shift kit in it. comes with a full size spare with 90% tread. I have the tan top also, still in good condition, i just liked the look of the black better, you can have whichever one, or both.
NEW
Windshield
full exhaust: Long tube headers, dual pipes with turbo mufflers, sounds great.
ignition: jegs coil (49,000 volts), cap and rotor, jegs 8mm plug wires, and spark plugs.
air filter
oxygen sensor
new-ish battery
Bad
No radio or speakers, but i got some extra stuff lying around i can probably throw in there with it.
Power windows don't work, the rear does, but somewhere in the wiring it is messed up, so i just put 12v right to the motor, and it works fine.
Some interior panels off, but will probably have them all back in.
Rusty, but i put rust stopper on the big areas, so it should not get much worse.
The truck runs strong, and i wish i could keep it, but i'm getting another truck, and i can only keep one. the truck is located in berkley MI. If you have any questions, call Josh at (248) 259-5375.
$1300 obo
udjlax is offline   Reply With Quote
Old May 9th, 2008, 10:41 AM   #2
udjlax
udjlax's Avatar
bump for a new price.
Page generated in 2.10649 seconds with 29 queries
