My tubing bender build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 4th, 2008, 06:53 PM   #1
firehawk
Live Action!
firehawk's Avatar
Default My tubing bender build
I am in the prcess of building a hydraulic tubing bender.
Build is based off of a buildup I found on the internet.
Old May 4th, 2008, 07:22 PM   #2
Tab
Tab's Avatar
Thats funny, I'm fixing to get started converting my Pro tools 105 too. I just got the 12v hydro pump and some steel for the base. Looking good. Is that a tsc ram? how much?
Old May 4th, 2008, 08:24 PM   #3
firehawk
Live Action!
firehawk's Avatar
Why did you get a 12v pump?
I have both and have not decided which one to use yet.
Obviously the 12v will work with a car battery or a transformer, but any other reasons?
I bought a Lion 2500 $114 http://www.northerntool.com/webapp/w...-_-1206-_-CONF
If you have any questions feel free to ask. I am still figuring it out but have it mostly done.
Just need to grab 2 1" bolts and finish welding it up then get the hydralic hoses figured out.
FYI I spent about $170 in steel for the stand alone. I think I might return a piece of angle that I might not need. So about $140 then, man steel is getting expensive.
Old May 4th, 2008, 08:36 PM   #4
kickstand
circling the drain
kickstand's Avatar
that stand looks nice jay.
Old May 4th, 2008, 08:53 PM   #5
firehawk
Live Action!
firehawk's Avatar
Thanks, it cost a lot more than I thought but it will last forever. It is heavy as F&*%! I need to put some wheels on it next.
Is it like the other two you have seen/used?
Old May 4th, 2008, 09:05 PM   #6
kickstand
circling the drain
kickstand's Avatar
I posted some pics of Mike's bender I thought, it looks like the design/idea is similar, I will have to look at the bender that is in my brother's garage and take a peak.
I am by no means a bender, but I can grind :tonka:
Old May 4th, 2008, 09:07 PM   #7
Tab
Tab's Avatar
I just got some I beam for the main top piece. I have scrap for everything else. I got a 12v because I thought it would be easier to find since they are used for plows, tommy lifts, pumps ect on trucks and stuff. I sorta like the idea of having a battery or battery charger built into the stand and being able to use it out in the driveway or something. I dont know maybe I just talked myself into it because thats what I've been searching for for two years off and on. What is your pump? Did you get it new or used?
Old May 4th, 2008, 09:10 PM   #8
Grinder
where did you find your build at?
Grinder is offline   Reply With Quote
Old May 4th, 2008, 09:20 PM   #9
firehawk
Live Action!
firehawk's Avatar
I bought a new 12v off Ebay, and a used 120v from ebay as well.
I liked the idea of no wires also, but the used 120v pump was $100 shipped.
Old May 4th, 2008, 09:23 PM   #10
firehawk
Live Action!
firehawk's Avatar
Here are two that are similar. The second one is a little more detailed. http://www.mindspring.com/~jayk5/bender/
http://reference.toolandfab.com/writ...bpage/body.htm
Old May 4th, 2008, 09:28 PM   #11
firehawk
Live Action!
firehawk's Avatar
Just went and looked at those pics again and I could have saved a ton of $$$ if I would have used an old engine stand and did it like Mikes.
But mine should have more travel, if that matters. I need to learn how to use it.
Old May 5th, 2008, 06:50 AM   #12
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
where are you buying your metal sounds pricey
Old May 5th, 2008, 11:53 AM   #13
firehawk
Live Action!
firehawk's Avatar
Metal Mart. But I will be calling around this week for the tubing.
Old July 21st, 2008, 07:29 PM   #14
firehawk
Live Action!
firehawk's Avatar
Update on the bender
Old July 25th, 2008, 02:02 PM   #15
firehawk
Live Action!
firehawk's Avatar
Now I need to know what this thing on the top of the pump is.
Could it be for an electronic controller for the hydraulic fluid instead of a three way valve?
Old July 31st, 2008, 11:17 AM   #16
firehawk
Live Action!
firehawk's Avatar
Here it is completed.
Old July 31st, 2008, 11:18 AM   #17
firehawk
Live Action!
firehawk's Avatar
Now to build a cage, tube doors and maybe bumpers for this.
Old July 31st, 2008, 12:28 PM   #18
liv2mx
i like jungle gym's.
liv2mx's Avatar
nice buildup..that should come in handy..
Old July 31st, 2008, 01:39 PM   #19
Building one of those old Jeeps?
Old August 1st, 2008, 09:30 AM   #20
DUNE JUMP
DUNE JUMP's Avatar
Looks real nice- why did you go with the electric hydro pump rather than air/hydro like Harbor Freight sell? Speed? The one we set up isn't the quickest but all told cost about 100 bucks to convert. We did use a lot of scrap steel though...
Page generated in 0.45639 seconds with 83 queries
