i am very confused!!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2008, 08:21 PM   #1
jeep+mudd=:]
Default i am very confused!!!!
it is time to get tires for my yj and I have been shopping around. I have american outlaw 1 rims (15x8) on my jeep. but i have to ask what the freak is up with tire size. I am putting 30's on it but my question is do i get 30x9.5x15? i guess the real question is what size rim does a 9.5 tire fit on because all the rims i have found are either 8 or 10 wide so i dont get where the 9.5 fits in to the picture. if someone or someones could explain this i would be very greatful.
jeep+mudd=:] is offline   Reply With Quote
Old May 3rd, 2008, 08:31 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
dont worry about the rim width, it doesn't have to match the tire width.
You are safe to go about as wide as a 12.5 in tire, but dont get anything narrower than the rim width.
Also, get bigger tires. You know you want to.
Old May 3rd, 2008, 08:38 PM   #3
jeep+mudd=:]
i would like to go bigger but i am pinched for money.....(second child coming in july) so my budget is limited. I got a daystar 1 1/4 shackle lift so i figure that 30 is about as big as i can get since the yj is the "low rider model" for jeep.
Old May 4th, 2008, 01:13 AM   #4
jeeperbrian
GLFWDA member
you want the tire wider than the rim. im near rochester, if you need a hand pm me and ill help you out. also if your ordering tires you should go to the firestone place downtown next to knapp's donut's, they'll give you a good deal
Old May 4th, 2008, 01:34 AM   #5
Daniel
SFA Ranger
Daniel's Avatar
31x10.50's should fit, i think.
Daniel is offline   Reply With Quote
Old May 4th, 2008, 10:29 AM   #6
PavementPounder
PavementPounder's Avatar
I ran BFG MT KM 325/60r15's on an 8" rim and they were excellent. Pretty much the widest 31" tire you can get. According to Tirerack.com, they still make that size.
Old May 4th, 2008, 10:36 AM   #7
kickstand
circling the drain
kickstand's Avatar
Ran those on some 15x8's on my tj and on a yj, the yj was stock height.
Old May 4th, 2008, 10:52 AM   #8
thehawiianpunch
lift it...
thehawiianpunch's Avatar
Send a message via AIM to thehawiianpunch
i have 31x10.5 15's truxus mt on my 88 yj stock hight with no rubbing
thehawiianpunch is offline   Reply With Quote
Old August 25th, 2008, 08:48 PM   #9
Ready4Wheelin
Ready4Wheelin's Avatar
Hate to bump an old thread, but this is what my search brought up and it's close to a question I have. What's the narrowest rim anybody would suggest mounting a 33x12.50 on?? The rims I have are either 7 or 8" wide, not sure, but if it turns out they are 7's, will I be OK putting 12.50's on them?? Thanks.
Ready4Wheelin is offline   Reply With Quote
Old August 25th, 2008, 08:59 PM   #10
Sandals
Fucking Zen as Shit
Sandals's Avatar
The tire will be fine on a 7" rim, i ran 35x12.50's on a 7" Grand waggy rim without issue. Just make sure the rubber will clear you springs and shocks.
Old August 25th, 2008, 09:11 PM   #11
dodger889
dodger889's Avatar
7" rim the most that I would put on would be 10.5" wide tires unless you are going just off road only but road and off 10.5's to keep the wear some where right.
Old August 25th, 2008, 09:17 PM   #12
Sandals
Fucking Zen as Shit
Sandals's Avatar
Depends on what pressure you run.
I ran BFG Mud terrains 35x12.50's on a 15x7 wheel on a grand wagoneer for 4 years as a DD, racked up 55,000 miles and had NO wear issues.
I think i ran them at around 28psi perfect contact patch and handling
Old August 25th, 2008, 11:32 PM   #13
PavementPounder
12.5" tires will be fine on a 7" rim. 8" is ideal.
Make sure you are measuring bead-to-bead, not edge-to-edge.
Old August 26th, 2008, 09:16 PM   #14
Ready4Wheelin
Thanks for the info guys, I'm only going to be running them on a narrow rim until I find something wider. Not sure if they are 7" or 8" wide since there's tires on them now and I'm just eyeballing the bead with a tape measure, but they are custom with a bit of an offset so I don't think rubbing on the inside will be an issue.
Old August 26th, 2008, 09:54 PM   #15
scottie
Eye candy
scottie's Avatar
you have 8" rims now, and what did i tell you in the parking lot
Old August 26th, 2008, 10:09 PM   #16
kickstand
circling the drain
kickstand's Avatar
That you would let him put it in your butt if he was nice?
Old August 26th, 2008, 10:10 PM   #17
Ready4Wheelin
I told him I loved him.
Tags
dopey dodger889
Page generated in 0.38466 seconds with 74 queries
