Trans experts - 700R4 question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2008, 05:03 PM   #1
jbsjunk
Little Member
jbsjunk's Avatar
Default Trans experts - 700R4 question
I'm putting a 700R4 in my Ckerokee with a small block. I know the TV cable has to be addressed and I will be getting the correct brackets to set it up right. My question is the lock-up. Can I leave it alone and unplugged or get one of several kits and hook it up and have lock-up? I've heard conflicting stories on this weather it could hurt or burn clutches or whatever if it were left unhooked. Once done, it will be a driver. Mild small block and mild lift.
What's your take on this? The kit ranges from $75 to $150+ depending on what's included. I want to be a cheap bastard but don't want to kick myself in the nuts either.
Old May 3rd, 2008, 06:27 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
you can get a kit and make it a non-lockup. Or you can run a 12v source to the switch and by pass all but the 4th gear lock up pressure switch. So it lock up in 4th gear. Or you can get a diesel lockup valve and it will make it lock up hydraulically.
Old May 4th, 2008, 06:25 PM   #3
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
Unless someone has some proof to show otherwise, not having lock up will not hurt anything. Although if you are going to be driving it at highway speeds it would be nice, especially to squeeze a few more MPGs out of the v8.
Old May 4th, 2008, 09:01 PM   #4
frdboy
frdboy's Avatar
I would keep lock up, it really helps keep the trans. cool.
Old May 5th, 2008, 03:00 PM   #5
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
X2 Wiring it to lock up is pretty easy.
Old May 5th, 2008, 06:40 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
Yeah, it's not too bad. Been doing a bit of research on it to find the cheap way out. Think I'm just going to spend a bit and get the TCI or Painless kit.
Gracias for the tips.
Old May 9th, 2008, 09:57 PM   #7
special ed
Pickup Agent
special ed's Avatar
You can use an oil pressure switch, and it will lock every time it goes into 4th.
special ed is offline   Reply With Quote
Old May 15th, 2008, 12:15 AM   #8
gigglestick383
gigglestick383's Avatar
Default lock up
if i remember correctly the lock up wire is green all u need is a 12v source u can hook it up to toggle switch and turn it on when u want after u are up to speed just got to remember to turn it off before u come to a complete stop or it will stall like u forgot to push in the clutch on a manual trans but makes it nice because u dont get the comin hunt for gears that 700r4's are comin for on hills because u control it when u want it just ask if u have any Q's and i will get exact colors of wires for u and what not
Tom
gigglestick383 is offline   Reply With Quote
Page generated in 0.24826 seconds with 47 queries
