timing set - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 14th, 2005, 07:54 AM   #1
amc78cj7
amc78cj7's Avatar
Default timing set
Following the dieseling I reported about last week, I reset my timing according to the service manual. This is an ECM controlled TBI Chevy 350. I unplugged the tan and black wire from the computer and found the timing was advanced about 16 degrees past 0. I set the timing to 0, then replugged the wire. Now the computer adjusts the timing and I find the mark is like 30 degrees advanced of 0. It seems to run ok, but it seems odd that the computer would adjust the timing that far advance at idle (cold engine). Does this seem odd to any mechanics out there?
amc78cj7 is offline   Reply With Quote
Old November 14th, 2005, 01:28 PM   #2
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
i did the same thing on my truck a whhile back, 30 degrees seems a bit much at idle, i dont remember off hand what mine was but i think it was less than 20.
GMCsonoma94 is offline   Reply With Quote
Old November 14th, 2005, 03:09 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the timming is pushed out by the computor till it hears the "ping" then it backs off just a degree or two. then when you step down down on it and get the "ping" it adjust accordingly. and yes the advance can be as much as 37 BTC . the base setting is Zero just the way you did it.
Yetti
Old November 14th, 2005, 07:27 PM   #4
amc78cj7
amc78cj7's Avatar
Cool. Thanks Yetti. KillerB said that my Comp Cam might need to be set even further advanced that Zero. It is a mild Cam, but I can't imagine I'd want the computer adjusting it even further than 30 degree.
Old January 31st, 2006, 08:35 PM   #5
the BURB
as long as it wont start hard when it gets warm or spark knock under a bad load then dont mess with it
the BURB is offline   Reply With Quote
Old February 2nd, 2006, 10:47 AM   #6
Mclovin
"The Situation"
Mclovin's Avatar
It's not abnormal for that much adavnce from the computer.. the 350 TBI in my i set to a base of about 15-20 and the computer pushes it up past 40...
Page generated in 0.24793 seconds with 41 queries
