Grooved my swampers *pics* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 14th, 2005, 07:45 AM   #1
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Default Grooved my swampers *pics*
Well, I was a little bored after work one night last week....decided to groove the tires on the cruiser....
Here is the groover I used. Bought it last year, $65 on ebay or something like that....
Had to use the halogen lamp to help heat up the tire before grooving it.
front tire done
both tires done
Here are all the shavings from all 4 tires. It is about 3-4lbs worth
pic from the next day
Old November 14th, 2005, 08:53 AM   #2
Cool.
How long did it take to do this?
Once you've had a chance to try them out, report back on if you notice anything on the performance.
Old November 14th, 2005, 11:32 AM   #3
Chop
Mischievous Badger
Chop's Avatar
thats looks cool must have taken long
Old November 14th, 2005, 01:17 PM   #4
brimy311
brimy311's Avatar
it took about 2 hours to do all 4 tires.
I ran them this weekend at the badlands, i would say that they definatly work better now.
Old November 14th, 2005, 01:25 PM   #5
Cool....
I've got the same tires on my Toy that I'm building, so I think this will be something to do over the winter....
Old November 14th, 2005, 01:30 PM   #6
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
how good did that tool work? did you have any problems with that style groover?
GMCsonoma94 is offline   Reply With Quote
Old November 14th, 2005, 01:56 PM   #7
brimy311
brimy311's Avatar
it works good if you let it heat up and stay hot. Also helps if the rubber is warm.
This groover is good for moderate use, using it everyday would probably suck.
JcrOffroad.com
Like us on Faceook!
Old November 14th, 2005, 04:24 PM   #8
clarkstoncracker
lol
clarkstoncracker's Avatar
Originally Posted by Haggar
Cool.
x2
I just bought a set of boggers, I'm thinking I like your method
Old November 14th, 2005, 05:49 PM   #9
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Brian, thanks for posting these pics. My buddy just put a set of 35" Sx's on his Blazer. I was telling him we should groove them, but he wanted to see what the look like. Thanks
Old November 14th, 2005, 06:32 PM   #10
Icebreaker88
Icebreaker88's Avatar
I have a groover similar to that one that i bought new last year. I still havent grooved my boggers yet. A friend used it to cut the wear bars out of a set of worn out SX's and it looked like it worked pretty well. Actually his GF did 3 of the tires her self.
I am gonna try to get mine grooved before i take it out again.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old November 16th, 2005, 06:02 PM   #11
BMFmike
meh.
BMFmike's Avatar
Is there a method to the grooving maddness?
Old November 16th, 2005, 06:18 PM   #12
clarkstoncracker
lol
If you look at certain tire prints, they are mainly designed for forward motion. The problem is, flat lugs that aren't geared towards right/left tend to have alot of "trail slide".. Meaning, they work great going forward, but have a tendency to fall down slopes..
If you are going in one direction, on a side incline, boggers will not hold the trail very well.
Cutting grooves helps this
Plus, a flat lug does nothing.. For every extra groove you have, it is more grip on the trail
Old November 16th, 2005, 09:33 PM   #13
brimy311
brimy311's Avatar
they commonly refer to what CC discribes as "latteral sability".
I kind of followed a couple of patterns I have seen ppl use in the past on there TSL's. I wanted to split the center lugs to get the tire a little more bite.
JcrOffroad.com
Like us on Faceook!
Old November 16th, 2005, 09:55 PM   #14
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Plus what Brian has done to his center lugs will help them flex and conform more to rocks and trail obsticles.
Old November 16th, 2005, 09:58 PM   #15
BMFmike
meh.
BMFmike's Avatar
That looks really good and helpful, any change in noise on the road and at high speeds?
Old November 17th, 2005, 12:51 AM   #16
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
no noticeable noise at speeds in the cab of the truck while its on the trailer?
nixxerRsixxer is offline   Reply With Quote
Old November 17th, 2005, 08:16 AM   #17
brimy311
brimy311's Avatar
There was a slight whistle
The biggest difference I noticed, when trying to climb straight up on rocky surfaces it no longers wants to slide left or right. Before, if I would give it much gas and turn back and forth, the front end would want to slide sideways.
JcrOffroad.com
Like us on Faceook!
Page generated in 0.32736 seconds with 74 queries
