Ranger V8 Swap - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2008, 08:43 AM   #21
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
http://www.jamesduff.com/broncoII/engine.html
according to them only 2wd version need steering shaft mods
Bronco351 is offline   Reply With Quote
Old July 27th, 2008, 04:38 PM   #22
Drg racr
Drg racr's Avatar
It figures. It's always the 2WD's that are the problem. I started planning the build. I have a guy that's willing to narrow a 9" for me. As for the motor, I have a 302 Ford and a 383 Chevy.
Drg racr is offline   Reply With Quote
Old July 27th, 2008, 05:40 PM   #23
Daniel
SFA Ranger
Daniel's Avatar
My ranger has eight sparkplugs.
To bad it has a 2.5L
Daniel is offline   Reply With Quote
Old July 28th, 2008, 12:18 AM   #24
Bronco351
Powered by Ford
Bronco351's Avatar
stick w/ the 302, generally a reliable motor and wll probably fit better than the 383.
Old July 28th, 2008, 08:57 AM   #25
greenbronco79
greenbronco79's Avatar
I had a chevy 350 in my old ranger. It worked great except the distributer was in the back of the motor so I had to cut out some firewall and even then if I ran over any thing to big the distributer would hit and break caps. But if you wanted a good 351 m to rebuild Im dropping a 460 in my 79 bronco. I will probably be selling the 351m for $250 or so in a couple of weeks.
greenbronco79 is offline   Reply With Quote
Old July 29th, 2008, 08:39 AM   #26
Drg racr
Drg racr's Avatar
I bet a 351M would be a mighty tight fit, then I have to make headers and such. It would be fun, though.
I'll probably stick with the 302. At this point, I want to keep it in the 12's. I'm not going to cage it or box the frame right now. It's going to look totally stock from the outside, even a little beat up and in primer. A poor man's truck!! Believe me, I fit the profile.
Old September 23rd, 2008, 12:46 PM   #27
Drg racr
Drg racr's Avatar
I found a company, Allstar Performance, that makes a complete conversion kit for the V8 Ranger. it comes with the mounts, oil pan, fuel pump, oil filter relocator, headers and radiator. It costs around $650, but it sounds like it might be worth it.
Old September 23rd, 2008, 05:48 PM   #28
Bronco351
Powered by Ford
Bronco351's Avatar
Bronco Graveyard has a kit as well.
Old September 23rd, 2008, 05:56 PM   #29
insaneoffroader
insaneoffroader's Avatar
i have not been real impressed w/Allstar Performance products
insaneoffroader is offline   Reply With Quote
Old September 26th, 2008, 03:03 PM   #30
Drg racr
Drg racr's Avatar
I got a few guys telling me I can buy the parts separately cheaper from other sources. The biggest expense will be the headers. I could even make the mounts if I had to.
But, I got laid off for a few months, so now I'm going to have to put this project on hold again. Good thing is, I can drive it if I have to since it's still got the 2.9/5-speed.
Old October 3rd, 2008, 03:48 PM   #31
Drg racr
Drg racr's Avatar
Well, got some mounts coming, and I got my 9" rear. If I don't find a good 351W, I'll use the 302 I had given to me.
http://www.greatlakes4x4.com/vbimgho...gid=9254'][/url]
Old October 3rd, 2008, 06:33 PM   #32
Bronco351
Powered by Ford
Bronco351's Avatar
why not just use the 302 in the first place?
Old October 3rd, 2008, 10:51 PM   #33
alboy79
Where's your loyalty lie?
alboy79's Avatar
pm'd you.
alboy79 is offline   Reply With Quote
Old October 4th, 2008, 08:59 AM   #34
Drg racr
Drg racr's Avatar
I wanted more cubes. I've run 351's before, and they make tons of torque. I could go with a stroker kit, but I didn't want to put a ton of $$ in the truck.
We got rid of the 383, so a Chevy implant is out of the picture. Who knows, I might run the 302 and see what it'll do.
Page generated in 0.28783 seconds with 65 queries
