2000 TJ FLuid All over ground -- HELP!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 8th, 2006, 09:24 AM   #1
Saharaboy
Donate to Me
Saharaboy's Avatar
Send a message via AIM to Saharaboy
Default 2000 TJ FLuid All over ground -- HELP!!!
Ok the fluid looks like power steering fluid or maybe brake fluid, not sure, but from where it looks like it is dripping doesn't make sense to me.
HELP!!!
Saharaboy is offline   Reply With Quote
Old April 8th, 2006, 09:54 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Yetti
Old April 8th, 2006, 10:07 AM   #3
Saharaboy
Donate to Me
Saharaboy's Avatar
Ya I know, but why would it leak from there?
Old April 8th, 2006, 10:19 AM   #4
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
if it's power steering fluid, then you can find out real easy by looking at the lines. they're not that long. they only go from the pump to the box and back. if it's leaking it's pretty obvious.
is the fluid anywhere else above or next to the motor, or is it just below your pulley there???
scorpio_vette is offline   Reply With Quote
Old April 8th, 2006, 10:25 AM   #5
Saharaboy
Donate to Me
Saharaboy's Avatar
From what I can tell it is just below my pulley there, don't see it coming from anywhere else....
Old April 8th, 2006, 10:36 AM   #6
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Hey john look on the back of the power steering pump see if it is wet. Also check the lines up there. Look at where the power steering hoses go by the steering shaft. if I remember correctly they looked worn as well as polishing a spot on the steering shaft. It may have worn a hole in the power steering hose.
Old April 8th, 2006, 10:55 AM   #7
Saharaboy
Donate to Me
Saharaboy's Avatar
Bill,
It is definatly not the hose, and for the most part the pump looks pretty dry, just dirty...not really sure.
I am assuming you are home, think I could bring it over for you to look at?
I tried calling but you didn't answer.
Old April 8th, 2006, 11:32 AM   #8
Saharaboy
Donate to Me
Saharaboy's Avatar
anyone else have a guess?
Old April 8th, 2006, 11:44 AM   #9
5.9zj
5.9zj's Avatar
could it be a little bit of coolant dripping from your water pump?
5.9zj is offline   Reply With Quote
Old April 8th, 2006, 11:59 AM   #10
Saharaboy
Donate to Me
Saharaboy's Avatar
It is definatly coolant....I filled my resovior last weekend cause it was low and now its down to the ADD part again....
FUCK!!!
ANYONE WANT TO BUY A TJ???
Old April 8th, 2006, 02:30 PM   #11
Tonka
Tonka's Avatar
I'm willing to bet you just need a water pump. there is a weep hole that will leak a little fluid when it goes bad. They are fairly cheap.
Old April 8th, 2006, 02:39 PM   #12
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
yep, what i was thinking. I've got through a few.
Old April 8th, 2006, 02:41 PM   #13
Sonicjay
I think I may have a water pump for you. I replaced mine once trying to solve another problem. I'm pretty sure it's still good.
Sonicjay is offline   Reply With Quote
Old April 8th, 2006, 04:08 PM   #14
Saharaboy
Donate to Me
Saharaboy's Avatar
It is the water pump, and I got a brand new one at murrays for $33, also picked up a new belt since its coming off anyways.
Thanks everyone for your help!!!
Old April 8th, 2006, 06:05 PM   #15
Gunsworth
Gunsworth's Avatar
haha, was gonna say to check all yer fluids and see which one is low, glad to see ya figured it out....water pump is not a bad job either
Page generated in 0.25161 seconds with 68 queries
