Towing - question on appropriate tie downs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 24th, 2008, 02:01 PM   #1
toy4x4boy
NO HABLA JEEP
toy4x4boy's Avatar
Send a message via AIM to toy4x4boy
Question Towing - question on appropriate tie downs
I'm wondering if these tie downs that I found on Ebay are appropriate for tying down my 4000 lb truck to a trailer. It says the working load limit is 2000 lbs for each assembly, but I don't understand this well enough to know if having 4 straps equals a total working load limit of 8000 lbs. Let me know your thoughts or if you have other recommendations. Thanks!
http://cgi.ebay.com/ebaymotors/4-AUT...spagenameZWDVW
toy4x4boy is offline   Reply With Quote
Old April 24th, 2008, 02:35 PM   #2
XXXJ
Desert Rat
XXXJ's Avatar
Home Depot has the same straps
Lowes might
Summits are better.
I bought from all three
Old April 24th, 2008, 02:51 PM   #3
toy4x4boy
NO HABLA JEEP
toy4x4boy's Avatar
So you are saying that they are acceptable and are strong enough to handle 4000 lbs?
Old April 24th, 2008, 04:38 PM   #4
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
It appears so.
I bought mine at Sam's Club for I think $12/strap
Old April 24th, 2008, 04:49 PM   #5
Arnie897
y=mx+b
Arnie897's Avatar
Send a message via AIM to Arnie897
I got my 4 at TSC. $16.99 each
$72.04 out the door.
2in x 27ft
3300 SWL
Long enough to haul things other than cars if needed. I just loop them around when I need to. Don't know if it doubles the SWL, but it makes me feel better.
Arnie897 is offline   Reply With Quote
Old April 24th, 2008, 04:49 PM   #6
XXXJ
Desert Rat
XXXJ's Avatar
I used two on each axle to haul this from Kaliphornya
Old April 24th, 2008, 04:58 PM   #7
XXXJ
Desert Rat
XXXJ's Avatar
I don't know if I like the floating "D" ring for the axle. I have never seen that.
I use separate axle straps.
Old April 24th, 2008, 05:03 PM   #8
toy4x4boy
NO HABLA JEEP
toy4x4boy's Avatar
2in x 27ft
3300 SWL
My only issue with those Mike is they don't come with axle straps like the Ebay ones. I plan to tie it down via the axle, truck is a little too long I think to tie to the bumpers...the straps would be virtually straight up and down, not much angle from trailer attach point to bumper, doesn't seem it would be too safe that way.
Thanks for the replies guys!
Old April 24th, 2008, 05:08 PM   #9
Arnie897
y=mx+b
Arnie897's Avatar
When we bround the WJ home from Florida we had to do the axle thing because she didn't have body mounted tow points. There was quite a bit of movement IMO.
Old April 24th, 2008, 05:29 PM   #10
toy4x4boy
NO HABLA JEEP
toy4x4boy's Avatar
Do you mean that the body moved around alot or the whole Jeep? I can see the body bouncing around, but not the whole thing moving on the trailer.
Old April 24th, 2008, 05:33 PM   #11
toy4x4boy
NO HABLA JEEP
toy4x4boy's Avatar
If 2 on each axle was enough to haul that beast, it'll be enough for my truck. I don't see any downside to the d-ring being part of the strap. I'll probably just pick these up.
Old April 24th, 2008, 05:34 PM   #12
Renegade II
Coil springs are for pens
Renegade II's Avatar
x2
Nice straps, great price @ Sams.
Old April 24th, 2008, 06:44 PM   #13
Arnie897
y=mx+b
Arnie897's Avatar
Body Movement = More Swaying
At least that's the way it felt.
Old April 24th, 2008, 07:38 PM   #14
toy4x4boy
NO HABLA JEEP
toy4x4boy's Avatar
That's what I thought. I think I will tie the axles down and then get a couple of those straps you got and run them through the d rings on my bumpers and secure it that way too.
Old April 25th, 2008, 09:12 AM   #15
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
i always tie to axles, never body...
as for those straps, i have a similar set of straps with the floating d ring, they work, but occasionally will loosen up, i stop and check them every once in a while
Viperdave is offline   Reply With Quote
Old April 25th, 2008, 09:35 AM   #16
kickstand
circling the drain
kickstand's Avatar
I always tie to the body, not the axles, cinch it down and take the suspension out of it, less sway.
Old April 25th, 2008, 09:40 AM   #17
cham
Inconsistant at Best.
I have that same pic of my mustang on a trailer from 05. Devils Tower in the background?
cham is offline   Reply With Quote
Old April 25th, 2008, 09:48 AM   #18
XXXJ
Desert Rat
XXXJ's Avatar
I have another pic with a tinfoil hat on my head.
I could spend a week crossing Wyoming. We traveled the back roads and saw a bunch of cool stuff.
Back on topic, I tied the axle, and then cinched down the suspension to keep the bounce down.
Page generated in 0.43344 seconds with 77 queries
