need some gauge help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2008, 08:57 PM   #1
masterbeatty
masterbeatty's Avatar
Default need some gauge help
well i have a pillar gauge pod and am wanting to hook up my oil pressure and my temp sensor. its a 94 bronco with a 302. e4od. where might i hook these up.
Old April 23rd, 2008, 09:05 PM   #2
bigcountrysg
Countryboy
bigcountrysg's Avatar
Is the oil pressure gauge mechanical or electrical. The temp sensor just find a plug remove it with an allen wrench and screw the temp sending unit in. Then wire it up. There should be a plug near the thermostat housing.
bigcountrysg is offline   Reply With Quote
Old April 23rd, 2008, 09:07 PM   #3
mudbillyredneck
mudbillyredneck's Avatar
.:tonka:
mudbillyredneck is offline   Reply With Quote
Old April 24th, 2008, 07:12 AM   #4
masterbeatty
all of its mechanical. i have a good idea on the oil pressure but, i was told there was a fitting on the intake manifold but couldnt find one.
Old April 24th, 2008, 08:35 AM   #5
kickstand
circling the drain
kickstand's Avatar
http://www.greatlakes4x4.com/showthr...90#post1070490
Old April 24th, 2008, 10:09 AM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
Oil pressure port/sensor is located behind the power steering pump on the side of the block. I currently have a truck in my backyard laying on it's side if you want or need a pic (it's easy to spot...hard to reach)
Old April 24th, 2008, 07:36 PM   #7
masterbeatty
umm i think i gound it does it have one wire leading off it?
Old April 25th, 2008, 08:12 AM   #8
fsumotorhead
N8KVB
yep
Old April 25th, 2008, 11:02 PM   #9
mudbillyredneck
:tonka:
Old April 25th, 2008, 11:13 PM   #10
masterbeatty
Originally Posted by mudbillyredneck View Post
:tonka:
keep laughn ull get urs
Page generated in 0.33128 seconds with 53 queries
