2003 F-250 axle question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 22nd, 2008, 08:38 PM   #1
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Send a message via AIM to NoShow Send a message via Yahoo to NoShow
Default 2003 F-250 axle question
I picked up a 2003 F-250 used about 2 years ago. About a week ago it began to shimmy real bad when applying brakes. I know its not rotors cuz its all in the steering wheel. Anyone else come across this? Drag link under there?
Also I climbed under to look at it and looks to have a possible junkyard axle in it, does anyone know where I can cross reference axle serial number to see what year it was produced etc??
Thanks
NoShow is offline   Reply With Quote
Old April 22nd, 2008, 08:45 PM   #2
frdboy
frdboy's Avatar
Sounds like warped rotors, sometimes you can feel it in the steering and not in the pedal.
I would check the ball joints also as they are known to wear out as early as 70-80k but most of the ones we do have around 120-130k on them.
Old April 22nd, 2008, 09:32 PM   #3
FORD FLARESIDE
6'-1" 185lb 14YO Griffin
FORD FLARESIDE's Avatar
The stock rotor's are laminated, if you are a heavy breaker, (such as pulling a trailer without trailer brakes) it will cause that lamination to blister. This in turn causes vibration under braking.
I found this out while hauling a dump trailer.
Usually if the vibration only happens when you apply the brakes, it will be in the braking system.
Old April 22nd, 2008, 09:40 PM   #4
NoShow
Mmmmm Beeeer...
NoShow's Avatar
I am going to pull tires but I only pull boat 3 miles on side streets with surge brakes. It could be possible, but the steering wheel goes nuts never have run into this... Truck only has 55k on it and I put about 23k in 2 years mostly driving fam to camping etc no trailer...
Old April 22nd, 2008, 09:42 PM   #5
FORD FLARESIDE
I lost the rotors at 60k, wheel bearings at 80k, and ball joints around 90k.
The good news is that the replacement parts seem to hold up better.
Page generated in 0.18725 seconds with 38 queries
