Rockford Fosgate CD/MP3 -- $60 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 22nd, 2008, 08:07 AM   #1
linuxrick
linuxrick's Avatar
Send a message via Yahoo to linuxrick
Default Rockford Fosgate CD/MP3 -- $60
This was in my old 1999 jeep TJ for about 8 months, then some punks broke in and took the face plate. After about 2 months I finally got a replacement from rockford fosgate but it had a small crack in it from shipping. You can make it out in the picture, I didnt even remove the plastic they put on for shipping. It has been packaged up in the box ever since. I took it out to take pictures.
RX9300 model
Comes with:
- remote control
- faceplate carrying bag
- TJ wiring harness already installed
- Preout/in patch cords
linuxrick is offline   Reply With Quote
Old April 22nd, 2008, 08:12 AM   #2
medicbear
Ax me bout ebonics!
medicbear's Avatar
how well does this do against bumps and vibrations if you know? im lookin for a new radio for my motorcycle...
medicbear is offline   Reply With Quote
Old April 22nd, 2008, 08:14 AM   #3
linuxrick
linuxrick's Avatar
If I remember correctly, it was better than the old factory Jeep CD player it replaced. That skipped like crazy even on the road.
Old April 22nd, 2008, 08:52 AM   #4
silverxj
Recovering XJ owner
silverxj's Avatar
If this has rca preouts for front / rear / and sub, I'd be very interested.
Old April 22nd, 2008, 09:25 AM   #5
linuxrick
linuxrick's Avatar
I just checked some specs online, looks like it does ? :
Summed Preamp Outputs: In addition to the front and rear preamp outputs, this unit has a set of summed preamp outputs. The summed outputs provide a summed left-plus-right mono output through two female RCA connections. The summed output is meant for connecting a subwoofer amplifier. For convenient level matching with the rest of the system, the summed output level may be independently set from 0 to 30. In addition, the outputs have a selectable low-pass filter, allowing you to choose 80Hz or full-range operation.
Auxiliary Inputs: Two sets of female RCA jacks are provided to allow the connection of portable audio sources. Just connect your portable cassette, MD or MP3 player to this unit, and you can listen to the audio from the portable player through the speakers in your mobile audio system. Each Aux input level is adjustable and can be set to -6, 0, or +6. The jacks are located on the 10" long preamp input and output wiring harness, which connects to the back of the unit.
Old April 22nd, 2008, 09:44 AM   #6
Lemur
i don't much care for you
Lemur's Avatar
very interested...is the crack all the way thru the lcd? or is it like a deep scratch?
Lemur is offline   Reply With Quote
Old April 22nd, 2008, 10:17 AM   #7
linuxrick
linuxrick's Avatar
I will take a closer look, just looks to be the covering plastic piece over the LCD but I have never hooked it up to see or removed that protective plastic cling.
Old April 22nd, 2008, 12:59 PM   #8
Lemur
Lemur's Avatar
Let me know as soon as you find out. PM me, I am very interested
Old April 22nd, 2008, 01:01 PM   #9
linuxrick
linuxrick's Avatar
I will check it when I get home from work around 4:30 and PM you.
Old April 22nd, 2008, 04:22 PM   #10
linuxrick
linuxrick's Avatar
Just checked its on a plastic cover over the lcd
Old April 24th, 2008, 11:58 AM   #11
linuxrick
linuxrick's Avatar
back to top, come and get it.
Old May 6th, 2008, 07:53 AM   #12
linuxrick
linuxrick's Avatar
Reply PMs sent but as of now, still have it.
Page generated in 0.23123 seconds with 59 queries
